Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
  • JoseJX
    • Dec 2010
    • 7
    #61
    Re: Westinghouse L2410NM 24" LCD power goes on and off, blue light flickers
    Originally posted by alexanna
    Something to try,
    With the monitor apart try to position the LCD as it would normally be positioned. I have found problems with ccfl wiring may take much longer to present with the panel laying flat.In its normal position heat will rise and cause a problem to occur much quicker.
    Al.
    I have had the monitor in an upright position since I took the back off. I still have not had the flicker occur again. I did try to briefly hit the power supply with a hair dryer, but did have any luck reproducing the flicker. I'll try again later with a more powerful hair dryer.
    Another thing that leads me to believe the problem is related to the capacitors is that there is a loud, high pitched whine when the power is plugged in, but when the monitor is off. It sounds like a capacitor continuously charging. When the monitor is on, it's still there, but at a much lower volume.
    Thank you all for helping!
    • Minathevi
      • Nov 2010
      • 8
      #62
      Without the backing on the monitor, I still get the same amount of flicker so it's not a heat issue for me. I'm beginning to think that the 1000uF cap near the wiring harnesses is the culprit. It's not bulging in the center like you would normally see, but it appears to be bulging around the edges ever so slightly. I'm not sure if you can tell in the picture, but in person the top is not flat like the rest of the caps.
      In regards to JoseJX's monitor, is it possible that there is some sort of intermittent grounding going on when the backing is in place? Just a thought because there are several points in which the backing comes close to all of the boards.
      • retiredcaps
        • Apr 2010
        • 9271
        #63
        Bad caps can cause flicker. I can't tell in the pictures, but caps do not have to be bulging to be bad. They can be out of uF tolerance and/or have high ESR (ohms).
        --- begin sig file ---
        --- end sig file ---
        • jetadm123
          • 2169
          #64
          Looks like they're using some good quality caps. Even good quality caps can go bad working under adverse conditions. They look like UCC KY series caps. Yes, bad caps can cause a whine. Minus the large 450V cap I count something like 9 smaller caps. If you order Panasonic FM/FC series caps from digikey.com, it should run you $11-$12, including shipping.
          • retiredcaps
            • Apr 2010
            • 9271
            #65
            I noticed that cap prices have increased quite a bit in the last month. Also, I noticed digikey and mouser dropped their discount price for qty=> 10. The new threshold is 50 caps.
            • jetadm123
              • 2169
              #66
              Yes, Digikey has dropped their qty=10 discount. And it was a great discount while it lasted. Unfortunately, I don't do enough repairs to justify a purchase of 50 caps per value at once. However, I started to look at the UCC KY series caps at digikey and they still offer the qty=10 discount. The specs aren't as good as the Pany FM series, but still acceptable. Digikey is still hard to beat if you're just buying a few caps and use the USPS first class shipping option.
              • Boregy
                • Dec 2010
                • 21
                #67
                Guys I think I have the same problem.
                I want to take a look inside, but I'm having some trouble getting the metal cage surrounding the electronics off. Any tips?
                Thank you.
                • Boregy
                  • Dec 2010
                  • 21
                  #68
                  Nevermind, I got it off finally. It was the 2 screwed on the VGA plug that I didn't realize I needed to get off.
                  Pictures to follow.
                  • Boregy
                    • Dec 2010
                    • 21
                    #69
                    Here's some pics, more to come.
                    • Boregy
                      • Dec 2010
                      • 21
                      #70
                      here's the rest. I suspect 2 caps are bad, maybe more.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #71
                        You definitely have at least 2 caps. The Capxon cap just right of the fuse KOAC and Capxon underneath the heatsink.
                        Capxon has a poor reputation here so most will automatically replace any Capxon cap.
                        What brand is the brown caps?
                        Replace all the Capxon capacitors with high quality low ESR caps from this list.
                        https://www.badcaps.net/forum/showthread.php?t=2280
                        Members here like digikey.com and order Pansonic FM caps for replacements. You can also support this site by choosing Rubycon and/or Samxon caps.
                        • Boregy
                          • Dec 2010
                          • 21
                          #72
                          Thanks for the input!
                          did you mean the two little brown caps near the one big brown cap?
                          image 73 is of one of the smaller browns, image 74 is of one of the medium browns under the heatsink.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #73
                            Those and the ones underneath that big heat shield.
                            If they are Capxon, replace them all. The main filter capacitor (biggest one) rarely, but not never, fails.
                            • Boregy
                              • Dec 2010
                              • 21
                              #74
                              ok, I added pics to the previous post.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #75
                                Is there a name on those caps?
                                • Boregy
                                  • Dec 2010
                                  • 21
                                  #76
                                  I see Capxon written on the back of one of the small ones, and one of the medium ones.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #77
                                    Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
                                    The caps were made in 2007. The P721 denotes 2007 and week 21.
                                    It is not uncommon to see Capxon caps last only 3 years and then die.
                                    Given their poor status here, most suggest replacing all your capacitors. If you live in the USA, you can follow PlainBill's instructions on how to order Pansonic FM or FR caps at digikey. FR are the newest caps and some may be "on order".
                                    https://www.badcaps.net/forum/showpo...33&postcount=2
                                    If FM and FR are not available, then choose Panasonic FC.
                                    • Boregy
                                      • Dec 2010
                                      • 21
                                      #78
                                      So it seems like every capacitor in my monitor is made by CrapXon, I counted 13 I should replace...I've never soldered before, any soldering guides?
                                      Thanks again for the help
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #79
                                        13 new caps + shipping (choose first class - it should be around $2.75 USD and you get it in a couple of days) from digikey should cost less than $15 USD total. I think for a 24 inch monitor, it is worth the $15 cap investment. To put that in perspective, when you buy a new computer monitor in Canada, there is a $12 CDN environmental fee.
                                        The best video for soldering is by CuriousInventor at
                                        http://www.youtube.com/watch?v=I_NU2ruzyc4
                                        I prefer using a desolder pump versus a solder wick. You will probably need a 30W or 40W iron.
                                        If you have some junk boards, practice on that first.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #80
                                          And I forgot this forum has an excellent guide on soldering at FAQ section
                                          https://www.badcaps.net/forum/showthread.php?t=485
                                            Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-07-2024, 05:50 AM
                                            Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
