Dell e171fpb monitor no power or LED lights
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell e171fpb monitor no power or LED lights
    Originally posted by miamiflorida
    Well, none of the others pins puts out anything.
    'Puts out' has such a naughty connotation. I much prefer 'reads 0 volts', or what ever the reading was. Well, we've established the voltage into the IC is low. The two possible causes are the IC is bad, or for some reason the source isn't delivering enough voltage.
    The two pictures in post number 7 cover the area I am interested in. I need a sharper picture of the top, and also a good, sharp picture of the bottom of that area.
    Alternatively, there are several large resistors on the top side of the board in that area. With power unplugged, check the resistance of each of them and compare it to the color code.
    The UC3842 is quite inexpensive - as low as $1.14 each, but I'd rather make sure I have you order the correct part rather than blindly replacing it.
    PlainBill
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      well you said have the transformer wasnt owrking. afaik thats the prob righ there...
      • alex.eaglemtn
        • Jan 2011
        I made a huge error. When disconnecting the screen I forgot to mark which way the back light connectors. Since they can be inserted either way, does anyone know the proper way to insert these connectors. There are two identical connectors. Any help would be greatly appreciated!
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          On all monitors i've worked on it's been pink wire up.
          A working TV? How boring!
          • Rtech
            • Jul 2010
            • 1095
            Every Monitor I have seen, the backlight connectors ALWAYS only fit into the sockets one way only,otherwise they will not make contact !!
            • Rtech
              • Jul 2010
              • 1095
              #26
              If you mean you have 4 connectors split into 2 Pairs(top & bottom),I don't mark which hole they go into. The length of the cable determines which pair of conectors must be used, and as far as I can remember, it does not matter which hole they are then plugged into as long as they are paired.,
              • sinhnguyen
                • Aug 2011
                #27
                i have tv vizio vp50-hdtv20A.power good when i turn on . but screen still black .
                could you please let me know which board in tv no good .
                thank you
                • PlainBill
                  • Feb 2009
                  • 7034
                  thank you
                  There are a number of problems with your post.
                  1. You posted in the Monitor and computer display section, not the TV section.
                  2. You hijacked a thread for a Dell monitor.
                  3. Some of the people here are very good, a few are brilliant. NOBODY can accurately diagnose this problem based on the information you provided.
                  4. This TV appears to have two problems - power supply failures and buffer failures.
                  Troubleshooting by replacing boards until you find the bad one is a way to fix a TV - it's an expensive way, but it works - usually.
                  PlainBill
                  • ratnesh3107
                    • Sep 2011
                    #29
                    Viewsonic va1616w Ca1 burn, no power problem, pls sugest ca1 capacitor value.
                    • Ifixstuff9
                      Dell SE2416h monitor power cycles - very weird behavior
                      by Ifixstuff9
                      Hello all,
                      I have a dell SE2416h monitor that power cycles at somewhat random intervals. When the monitor is first powered on after being off for a few hours, it lasts 15-30 mins before the first power cycle. After that, the cycles progressively get more frequent until the monitor cycles every few seconds.
                      I'm not sure what is causing this, but maybe something is overheating, causing the monitor to shut off? That would explain why it gets worse with time.
                      Now here is where things get weird (at least to me, this might be some some common symptom I've...
                      04-20-2019, 07:03 PM
                    • kitor
                      Dell Latitude 7390 - all power rails up except VCC_GT, no image.
                      by kitor
                      I have Dell 7390, LA-F311P.
                      AFAIK there's no schematics available, but there's one for LA-F312P in this thread. It differs in no Thunderbolt controller (iirc that's for 5290/5390), however rest of the schematics/BV seems to match 1:1.
                      Behavior:
                      Connected barrel plug, no RAM:
                      - power LED turns on + orange light on front
                      - turns off after a second or two
                      Connected barrel plug, with RAM:
                      - power led turns on + while light on front
                      - after a few seconds power led turns off, white light...
                      07-26-2022, 09:53 AM
                    • sikocan
                      Dell Vostro 5490 Not turning on. Orange LED when power button pressed only
                      by sikocan
                      Dell Vostro 5490
                      Service Tag: G8T7NW2
                      Motherboard Model: Mantis CML 18778-1
                      Schematics: Attached in the Google Drive folder.
                      BRD File: Attached in the Google Drive folder.
                      Video of the issue: https://youtu.be/bIXaiiub664 (Also on Google Drive)
                      Google Drive link: https://drive.google.com/drive/folde...j_?usp=sharing
                      I've attached Resistance Readings at 200ohms range. Voltage Readings, with and without power button being pressed. Detailed board pictures. Old and new BIOS files attached.
                      01-27-2023, 07:39 AM
                    • reid
                      Dell 7280 Power Issues (LA-E122P)
                      by reid
                      Hi, this is my first new thread and I am hoping to get some assistance troubleshooting a Dell Latitude 7280 (LA-E122P). I have fixed a few MacBook logic boards before, but I'm not familiar with Dell boards or schematics, so I don't really know what things are important to know or check first.
                      When I first got the laptop, it would not turn on. I'd plug it in and press the power button, the power LED would come on for a second and then turn off and the laptop wouldn't do anything. This was fixed by flashing the UC5 EEPROM, so I don't think there was any hardware issues when I first...
                      12-16-2021, 07:35 PM
                    • meraklinetx
                      Asus Z97-a power cycle, no boot no cpu voltage
                      by meraklinetx
                      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                      05-10-2023, 06:08 AM
