In my monitor the display S-PVA Samsung LTM201U1 is installed, it is powered by a voltage of 5v to 12v in where to use?
Dell 2007WFP Won't Power On
Re: Dell 2007WFP Won't Power On
ss
Thanks for that budm. Lord knows I have no idea, but I can't give up yet. I have some basic questions if you want to take a crack at them.
Please correct me if I am wrong and point me in some direction. I need to do some crawling before I can walk.
On my application, is my power board's main function to take 120V AC and supply 19V DC to the other boards (USB/DC, logic and inverter)?
And is one of the jobs of the USB/DC board to use the 4 "buck regulators" to make 3.3V, 5V, 12V and some other voltage available for use on that and the other boards?
I feel the power button goes to the logic board to get things started, but can you explain a little what happens?
Also, I have made a little sketch to try to better understand the "buck regulators". I borrowed your previous drawing as a start and would appreciate corrections and comments. If it is not valid, feel free to tell all not to use it. I am not claiming it to be correct.
MEB thanks for the schematic!
My 2007WFB rev a00 had Q2 populated as well.
Q2 is 5V output and its switched on via a signal from the cpu.
It is used to power the LCD and it goes straight trough pins 9-10 to the Logic board and straight to the LCD harness plug. Q2 is driven by the 2OUT of U3 TL1451A via a signal line through the connector to the logic board, i forget which one.
When the monitor goes to sleep the 5V is shut down so if you test that board out of circuit the voltage will not be present.
Another note for all the 12V output for the speaker is switched off until you plug something into the coax connector. This send a switch signal to the U4 TL1451A to turn the mosfet on via pin 2OUT.
Thanks to everyone most importantly to budm for his work. In my case it was the 2.7k resistor on U4 TL1451.
The very last thought is; there must be a reason they squirted the silicon on that one of four TL1451 pwn controllers. My unanswered question is why? Heat? Insulation? Anyone?Comment
Assuming...7 Photos -
by PantherDaveHi all!
I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. π
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Borse2008Hi everyone,
Looking for some advice or opinions on what to do with a monitor issue Iβve run into. Apologies in advance is this crossovers a few forum categories.
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display β it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- Thereβs
Today, 04:55 AM -
by Mark01Hi guys,
This is my first post! π
I have no idea what Iβm doing, but Iβm learning by trial and error.
Iβm currently working on a Dell Optiplex AIO 7490βone of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... - Loading...
