Samsung 245 BN44-00195A Supply
  • RP-USER
    • Aug 2010
    Anyone have a schematic of this PS? Unit has no 24v output. On board 82uf @ 450 Cap has only 160v. Board notes 380v.
  • pedro
    • 199
    • AUSTRALIA
    Re: Samsung 245 BN44-00195A Supply
    160V is about right if your line voltage is 120V. (Of course, if you are in the 220/230/240V parts of the world, 160V isn't good.)
    Friends don't let friends buy Samsung ....
    • PlainBill
      • Feb 2009
      • 7034
      As has been repeated many times, 'A picture is worth a thousand words.'
      Follow the link in my signature for information on attaching the pictures.
      PlainBill
      • Aruba
        • May 2010
        • 58
        This monitor has a power factor correction circuitry on the front end and therefor you should see 380-390VDC on the 82uF, 450V cap. When you measured the voltage across
        the 82uF cap and it was at 160V I am assuming you did this with a DVM. If the 82uF is
        very low in capacitance the voltage might be swinging from zero to 380V and giving you
        an RMS voltage of 160V on the DVM. If you have a scope you might want to see what
        the "real" voltage waveform is on this cap. I suspect it might be swinging from zero to 380V at a very fast rate. If no scope is available you might then try substituting a know
        good 82-220uF, 400V cap in the 82uF cap location and see if the 24V comes alive.
        • pedro
          • 199
          • AUSTRALIA
          First the big "CAUTION!!!" - both sides of the main input rectifier cap are live! Most CROs have a grounded reference. An isolation mechanism is required - either an isolation transformer in the CRO or (preferably) monitor supply line, or the more dubious floating chassis arrangement on the CRO which I would NOT recommend.
          The voltage on the cap WILL depend on the line voltage. As the O/P hasn't identified his/her location/country we cannot assume a line voltage.
          • Aruba
            • May 2010
            • 58
            Yes extreme caution should be taken whenever you are working on the
            primary (HOT) side of the circuit. The beauty of the power factor correction circuitry is that the bulk cap on the typical 400VDC bus will always be around
            400VDC when working correctly regardless of the input voltage which may be
            at 100VAC (Japan), 120VAC (North America), 208VAC (North America) or
            230-240VAC rest of the world. This is such that the current drawn of the
            equipment is more sinusoidal in sync with the voltage waveform rather than
            small current peaks only near the positive voltage peak and at the negative voltage peak. Power factor measured with the power factor correction circuitry installed measures very close to the ideal perfect power factor of 1
            at around 0.95-0.99. On equipment without power factor correction and is using a switching power supply is typically around 0.5-0.65.
            peak
            • montreal
              • Sep 2010
              • 15
              My IP board uses a full wave rectifier bridge to charge up the inverter capacitor. Since my line voltage is 120 VAC for North America, and the peak voltage is about 1.5 times that, it is normal to find about 170 volts DC in this can. Because the bridge is full wave, the peak voltage across the cap should never be more than 170 volts DC.
              In Europe with 220 Volts AC as the line voltage, 1.5 times that would be 330 VDC on the same can and an electrolytic with a 400 volt rating should be a comfortable fit.
              I have seen some fancy transformerless power supplies in my life which can create 340 volts DC from the 120 AC line voltage using a clever configuration of diodes and caps (called a voltage doubler).
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                09-07-2024, 05:50 AM
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
                03-31-2024, 02:12 PM
              • Cookybaby
                Samsung UN60ES6500FXZA Power Supply Issue
                by Cookybaby
                Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                Make: Samsung
                Model: UN60ES6500FXZA
                Power Supply P/N: BN44-00525A
                Symptoms: The TV was...
                08-20-2023, 12:26 PM
