Acer AL2423W Recapped, backlight works but no display
  • jetadm123
    replied
    Re: Acer AL2423W Recapped, backlight works but no display
    I forgot to add that you may also want to reseat the ribbon cable(s) that connect this board to the logic board.
  • jetadm123
    replied
    Hello! While we have not yet ruled out that the logic board could be bad, may I suggest you check to see if there is a blown pico fuse located on the circuit board connected to the LCD panel. This board (I forget what it's called) is located at the top and usually spans the entire width of the panel and is connected to the LCD display via a number of flat flex ribbon cables. This board may have metal or plastic shield over it.
  • retiredcaps
    replied
    Yup that is correct
    The black image seems uniform too
    Sorry, just to be more precise.
    It is all white screen, but with no graphics (not a black screen)?
  • Per Hansson
    replied
    Yup that is correct
  • retiredcaps
    replied
    So after these caps had been replaced the monitor turns the backlight on as soon as I give it power
    However there is no picture displayed, either with or without a VGA or DVI cable
    Just want to confirm that all you have is a white screen then with no display?
  • Acer AL2423W Recapped, backlight works but no display
    Hi, I got a free Acer AL2423W LCD monitor from work, it was not working when I got it, there was nothing at all when I plugged in the power cable
    I changed these capacitors on the power board and after that the backlight turns on and is lit properly, at this stage the monitor draws 51w at the power socket.
    (Actually I cheated and did not replace the 10uF CapXon because I had problems removing the grounding shield, also I did not replace the 450v bulk filter cap next to it)
    Code:
    10uF	50v	CapXon KF
    4,7uF	250v	CapXon KM
    22uF	50v	CapXon KF
    22uF	25v	CapXon GL
    33uF	35v	CapXon GL (x2)
    82uF	450v	CapXon KM
    100uF  25v   CapXon KF (x2)
    1000uF 16v   CapXon KF (x2)
    Code:
    Replacement Capacitors from Big Pope:
    1 x 10uF  50V Samxon RS
    1 x 4.7uF 250V Samxon RT
    1 x 22uF  50V Samxon GF
    1 x 22uF  25V Samxon RS
    2 x 47uF  35V Samxon RS
    2 x 100uF 25V Samxon GF
    2 x 1500uF 16v Samxon GC
    The two 100uF 25v capacitors sit at CS13 & CS16
    Also I replaced 2x 1000uF 16v caps at position CS15 & CS14 with 1500uF caps
    At positions CS10, CS11 & CS12 where United Chemi Con KY 25v 680uF caps that looked fine so I did not replace those...
    Also it is not possible to press any buttons, nothing happens, not even the standby button
    At this stage I left it alone for several months but now when I saw the other 3 threads on this monitor with the bad Teapo caps on the logic board I decided to replace those, even tho they looked fine on my monitor.
    However after removing them both their ESR and Capacitance was good (0.1 and 370uF respectively)
    I recapped it anyway with Samxon GC 470uF 16v caps, 8 in total
    I did not have a replacement for the 100uF 25v Teapo, however in circuit I measured it at 0.11ESR and 109uF
    At this stage there was no difference from before, but I tried something I had not done before
    A added the GPU-Z monitorinfo program in the startup folder and shutdown my computer, next I stated it up with the Acer, which gave no picture still.
    I waited untill the computer had finished loading and this is what I found when I connected back my Eizo LCD:
    Lastly I measured the voltage at the underside of the PCB in the attached picture, I saw 19v, 12v and 5v at the middle of the Power Schottky rectifiers legs at each specific secondary output in the image (i.e. left, middle, and right arrow respectively)
    If anyone has managed to read this far and would like to offer me some input on what to test next I would be very grateful!
    Last edited by Per Hansson; 10-28-2015, 11:45 AM. Reason: Correction about bulk cap model
    by momaka
    03-15-2023, 10:17 PM
    KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
    by momaka
    For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
    http://www.rmac.kingwin.com/products.../abt_650MM.asp
    I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
    What mostly drew me into buying it is its 2x PCI-E power connectors...
    03-29-2022, 11:34 PM
  • cap__
    Can I replace 15uf capacitor with 22uf?
    by cap__
    "If I wanted to replace an old 15uF/400V capacitor with a new one,
    I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
    11-29-2023, 11:16 AM
  • Y. Signal
    Recapping Mean Well MWP-606
    by Y. Signal
    Hello, I have this arcade power supply that I'd like to recap for maximum reliability and lifetime since I have found some Capxon and Jamicon capacitors:
    • Capxon GL 10x25 1000uf 16V Ripple: 1180 Impedance: 0.05ohm // Chemi-con KY 1000uf 16V Ripple: 1400 Impedance: 0.046ohm
    • Capxon GL 10x12.5 470uf 16V Ripple: 722 Impedance: 0.095ohm
    • Capxon GS 10x15 22uf 50V 85ºC Ripple: 100
    • Capxon KM 47uf 50V Ripple: 125
    • Jamicon TK 1uf 50V Ripple: 12
    • Jamicon TK 4.7uf 50V Ripple: 36
    I have another PSU (same model) that uses Chemi-con KY instead of Capxon GL, and since Panasonic FC are very...
    03-03-2019, 07:44 AM
  • bulkchart32
    i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
    by bulkchart32
    i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
    06-19-2025, 02:37 AM
