LED 27" monitor PSU issue - np power to LED array
  • dougieT
    • Aug 2022
    • 16
    • United Kingdom
    Hi all, picked up a faulty Hanns-g HL272HPB free for spares/repair hoping it was just a re-cap...
    I found 1 cap with a bulge and an out of spec reading.
    100uF 100V see pics.
    I've replaced it with a like for like value.
    Not so fast... still no power on
    More testing results next post.
    Dougie
  • dougieT
    • Aug 2022
    • 16
    • United Kingdom
    Re: LED 27" monitor PSU issue - np power to LED array
    So time for some readings...
    Heres a pic of the underside, there are 2 test points labelled on the PCB, one for 5Vdc and one for 24Vdc.
    I also read the mains AC (244Vac) and rectified DC at the 2 paralleled 53uF 450v filter caps (336Vdc).
    Took some readings at the other caps too, see pic.
    Dougie.
    • dougieT
      • Aug 2022
      • 16
      • United Kingdom
      I checked 2 surface mount TO-262 packages in the 24v test point area of the board, part numbers 050N10 and S20N10, desoldered and checked them in the mini tester. Also tested the gate switch function OK with a DMM. See pic for results.
      Dougie.
      • diif
        • Feb 2014
        • 6978
        • England
        E19 capacitor ok ?
        • CapLeaker
          Leaking Member
          • 8226
          Do you have BLon?
          • dougieT
            • Aug 2022
            • 16
            • United Kingdom
            Originally posted by diif
            E19 capacitor ok ?
            Looks like a slight bulge on it, took it out and measured in the mini tester. I replaced it with 2 x 47uF 63v in series and got a good spec and ESR.
            The replacement E19 caps read 39v across it.
            Dougie.
            • dougieT
              • Aug 2022
              • 16
              • United Kingdom
              Do you have BLon?
              No lights to indicate it's on after mains power applied, soft power switch doesn't light up.
              I took some readings from the AV panel driver board, pic attached.
              Dougie
              • lotas
                • Jan 2016
                • 4668
                • Russia
                Your problem may be in the motherboard, since 5v power is supplied to the board, but there is no command to turn on "EN".
                Check power to DC-DC converters.
                • dougieT
                  • Aug 2022
                  • 16
                  • United Kingdom
                  Here's some shots of the AV/logic board, top and bottom sides.
                  I don't see any obvious issues or where the fault could be on the board.
                  Dougie
                  • lotas
                    • Jan 2016
                    • 4668
                    • Russia
                    What are the voltages relative to earth at these points?
                    • dougieT
                      • Aug 2022
                      • 16
                      • United Kingdom
                      I've attached the photo with the 2 readings.
                      Thanks for your help
                      Dougie.
                      • lotas
                        • Jan 2016
                        • 4668
                        • Russia
                        You have a low voltage at the input should be 5v, at the output 3.3v.
                        • dougieT
                          • Aug 2022
                          • 16
                          • United Kingdom
                          The 5v to 3.3v regulator on my board is a CYT8117T33 and the IC it feeds its output to pin 3 of this package labelled "8912k 245168", can't find any info on the codes.
                          I checked he caps around them and all ok.
                          So 1st I'll order the 5-3.3v regulator and replace it.
                          Dougie
                          • lotas
                            • Jan 2016
                            • 4668
                            • Russia
                            This regulator is the same (1117 33) with a fixed voltage of 3.3v.
                            • lotas
                              • Jan 2016
                              • 4668
                              • Russia
                              8912k - APE8912
                              • dougieT
                                • Aug 2022
                                • 16
                                • United Kingdom
                                8912k - APE8912
                                Thanks, good find!
                                Both regulator IC output readings are low, but the 1.5v reg IC Vin is fed from the 3.3v reg Vout so we can assume the 1.5v reg is OK? It relies on the 3.3v from the other reg IC and Vin has to be 1.5v higher than Vout, its Vin is currently only getting 1.52v.
                                Could a fault in the 1.5v reg IC take out the 3.3v reg IC?
                                So, maybe best to replace both...
                                Dougie.
                                • lotas
                                  • Jan 2016
                                  • 4668
                                  • Russia
                                  It is unlikely that 8912k suffered, 3.3v not only power it, you can check by applying 3.3v from a laboratory power supply to this point and check.
                                  • dougieT
                                    • Aug 2022
                                    • 16
                                    • United Kingdom
                                    Yes, I wouldn't expect these ICs to draw much, datasheet notes 3A typical and 5A max and I wouldn't expect it to need that much.
                                    I applied 5v from the bench supply to pin 3/Vin on the 5-3.3v reg IC and got 3.3v pin2/Vout then tested at pin3/Vout on the 3.3-1.2v reg IC and it read 1.2v so all good there.
                                    The power LED lit up and I was able to power on/off the motherboard via the on/off button. I only connected the front panel button/LED board header and nothing else.
                                    So now to find out what has happened to the 5v supply we have from the PSU board header and the 5v-3.3v reg IC.
                                    Dougie.
                                    • dougieT
                                      • Aug 2022
                                      • 16
                                      • United Kingdom
                                      Very strange!
                                      I connected all the headers and the panel flat cable to test the 5v from the PSU header board again, the power led lit up and I cot a check cable message on the LCD panel
                                      I'll put everything back in the casing and test with an HDMI input etc...
                                      Dougie.
                                      • lotas
                                        • Jan 2016
                                        • 4668
                                        • Russia
                                        Check the connector and the passage of 5v to 1117 and the capacitors in the power supply on the 5v bus.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • justice171
                                          Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                          by justice171
                                          I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                          Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                          1. Verified that all critical voltages are present:
                                            • 3.3V and 5V are always present if DC is plugged.
                                            • 1.8V on the BIOS chip is present.
                                          2. Checked the power button functionality:
                                            • When pressed, the voltage drops to 0V, indicating the button is functional.
                                          3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                            • Confirmed connectivity is intact, ruling out issues
                                          11-26-2024, 12:39 AM
                                        • claws77
                                          lenovo flex 5 14itl05 power sequence issue
                                          by claws77
                                          hi guys, my motherboard will not start no matter what
                                          when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                          but rest nothing happens no sign of life.
                                          this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                          with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                          but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                          i have no knowledge of motherboards ....
                                          10-20-2024, 02:48 PM
                                        • yaya3gmax
                                          Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                          by yaya3gmax
                                          Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                          Symptoms:
                                          • Laptop works normally on a pre-charged battery.
                                          • Battery does not charge when adapter is connected.
                                          • Without battery:
                                            • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                            • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                            • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                          08-21-2025, 07:16 AM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
