Re: Sceptre x22wg-Gamer 22" LCD
U6 is probably an adjustable regulator. Do as jetadm123 suggested, but measure the voltage on all three pins of each regulator. The tab on each regulator is electrically connected to the center pin.
PlainBill
Wow, I can't believe I didn't think of that. I'll do that shortly and get it all typed out.
Well that poses a slight problem atm. I can't seem to find anything here that measures mm besides a protractor and the way it's shaped won't allow me to measure the height of them from the board. I'm going to have to remove them first to measure them, but I can tell just from the lead spacing that the small one I found isn't the right one and it's the only one they have at the right uf and voltage in the FC series.
Now that I know I can look in other series for that one though I should be good. Once I get them all out and measured and find a full set to buy I will post everything though. I truly appreciate all of your help so far. The only thing I'm not really so sure about is the operating temp. I know mine say 105c on them but it has a min and max on that digi key site and i don't know how to find the minimum. I don't think the minimum is as important as the max though anyway.Leave a comment:
U8 is probably a 1117-25L voltage regulator with 2.5V output.What are the chances the Pericom IC is still good, because if I would have to replace it, the pins are really tiny, and I'd need a heatgun to remove it, which I don't have, and then I'd have to remove all the caps which I just replaced and then reflow the replacement IC in the oven.
U6: AIC 6F7L / 1117L
U7: AIC 1084-33 / 0617 JL
U8: "5BAL / 17-25L"
I can't find the listing for U8.
U7 looks to be a 3.3V output.
U6 don't know output.
Suggest you take your DMM and measure the voltage outputs of U6,7 & 8.Leave a comment:
U8: "5BAL / 17-25L"
I can't find the listing for U8.Leave a comment:
If you want, list your original caps + uF + voltage + size + dimension, and your chosen replacements and we can verify for you.Leave a comment:
The voltage at pin 48 is a problem. Reading the specs on this IC, the MAXIMUM allowable voltage on the IC is 3.6 volts. 5V is high enough to destroy the chip.When the monitor is on and the CFLs are lit:
Pin 1: 0.03
Pin 48: 4.92~4.93
When the CFLs turn off and the screen goes into standby:
Pin 1: 0.01~0.02
Pin 48: 4.94
I have everything plugged in besides the data cable to the LCD panel inverter to take the measurements. Is this sufficient or should I instead plug that in, and attempt to draw a voltage off the CFL connectors while it is running and then test pins 1 and 48? And if so, what's your preferred method of drawing power from CFL connectors witout actual bulbs?
There is no need to have the CCFLs hooked up. This chip must be powered whenever the monitor is plugged into an outlet. Recall, it must be active, and passing signal to the graphics processor even on standby.
I would suggest identifying the source of power for this IC. U6, U7, and U8 are voltage regulators. What are the part numbers of those ICs?
PlainBillLeave a comment:
Yes, aluminum. Yes, you can mix/match manufacturers and series.Leave a comment:
Yeah I did all that, I just wanted to be sure it's aluminum since there were so many capacitor categories to choose from. Is it okay to mix and max different series between the medium and small capacitors? It seems they don't have the FM for the medium sized ones but only FC, and the only FC one they have for the small doesn't match the size of mine...Leave a comment:
Just follow PlainBill's instructions to the letter. When you click on aluminum, it displays a whole list of choices/filters.Leave a comment:
As I'm rather new to this I'm not sure, but the page you linked said to choose aluminum. Is it assumed that's the category I will need as well?Leave a comment:
mouser.com also has Panasonic FM and FC caps. mouser.com might be cheaper than digikey?Leave a comment:
Pin 1: 0.03
Pin 48: 4.92~4.93
Pin 1: 0.01~0.02
Pin 48: 4.94
I have everything plugged in besides the data cable to the LCD panel inverter to take the measurements. Is this sufficient or should I instead plug that in, and attempt to draw a voltage off the CFL connectors while it is running and then test pins 1 and 48? And if so, what's your preferred method of drawing power from CFL connectors witout actual bulbs?Leave a comment:
Great, thanks again for all your help retiredcaps. The "repair kit" I found is something like $13 and has all 8 of the medium sized capacitors and the small one, but it also doesn't list the exact brand or series that I will be getting. I will check out the site you mentioned and price it out and if I do go with the ebay kit I will be sure to verify first with the seller the exact ones I will be getting. It does state that they don't use capxon, but only Panasonic, Nichicon and Rubycon which are all recommended on the link you gave earlier.
Anyway I'll go ahead and look into the pricing and get it ordered and I'll check back in once it's done and hopefully working properly again.
If I look through my box of bad/bloated capacitors, Capxon is well represented. Many people here call the Crapxon.
Bad caps can cause all sorts of problems. No power, taking multiple times to turn on, taking longer and longer to turn on.
The first monitor I repaired had Capxon caps that went all bad. I replaced them with Rubycon MCZ caps and 8 months later the monitor is still running fine.
Assuming you live in the USA and you are really trying to save every penny, try costing out the capacitors at digikey.com and use USPS first class shipping (around $2.75 USD). Follow PlainBill's instructions on how to choose Panasonic FM caps. If FM is not available, then choose Panasonic FC.
https://www.badcaps.net/forum/showpo...33&postcount=2
Compare the ebay "kit" or digikey to see which is cheaper. I'm guessing the digikey with shipping will be less than $10 USD.
PS. Replace ALL the electrolytic capacitors except the biggest one, which rarely, but not never, fails. Trying to save 23 cents by not replacing the smallest cap (usually a 22uF 50V cap) can cause you grief later on.Leave a comment:
The original ones are CapXon. Mainly what I'm asking though is that if bad capacitors alone could cause the problems I described in my first post, and if replacing them would fix it.Leave a comment:
So 1 probe on pin 1 and one on ground?Check the power supply voltage(s) for the PI3HDMI412FTBE on pins 1 and 48. (There are many more pins, but those are easily probed - it's a 48 pin IC). The dimple is pin 1.
I checked the debug menu and I didn't see anything in relation to this.One other point - an earlier post mentioned 'fixing the x22wg from the menu'. Make sure the DVI and HDMI inputs are allowed - it seems strange that they wouldn't be, but....Leave a comment:
What brand are the original capacitors? Some have a very poor reputation.
Sorry, here is the link
https://www.badcaps.net/forum/showpo...30&postcount=7Leave a comment:
This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 05:20 AM
This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...09-07-2024, 12:10 AM
by Mad_ScienceI have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
03-01-2024, 05:05 PM -
by Justin_D33It doesn't matter the series - GL, KF, LX, PD, I don't care. If I see CapXon in anything, my instinct is always "get it out of there". Even if it "looks fine". They should be ashamed of themselves. CapXon = CrapXon (rightfully memed).11-25-2025, 09:27 PM
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... - Loading...
