Acer AL1916 Colour problem
  • terry
    • Oct 2007
    • 91
    • Milton Keynes, Bucks
    I have a Acer AL1916 lcd monitor with a strange problem. when I turn the monitor on the screen looks washed out, if I go in to the factory settings and reset the coulor in the eprom the screen is ok, I can turn the monitor off and on as many times as I like and it's still ok. The problem is as soon as I remove the power cable and leave it a couple of mins, then when I try it the screen is all washed out again, so I have to go in to the factory setting and reset the eprom.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Acer AL1916 Colour problem
    Either your monitor has an option to 'Save user settings', which you are not doing, or more likely the eeprom is corrupted, or defective. Google 'reset monitor' to see if you can find a reset sequence for the monitor. If that doesn't work, replace the eeprom.
    PlainBill
    • Radio Fox
      Acer AL1916 monitor PSU repair (DM0565R blown)
      by Radio Fox
      I'm repairing an Acer AL1916 monitor PSU at the moment. The 400v high voltage smoothing capacitor C114 is measuring completely O/C. The case of U101 has blown apart. Fuse F101 has blown. ZD121 reads 6 Ohms in both directions & ZD120 reads 99 Ohms in both directions. While looking at the data sheet of U101 (DM0565R), I noticed that the absolute maximum voltage for Vcc is 20v. However, the zener diode across the Vcc pin to GND is a 1N4748A (22v).
      Now, whether that zener is used to constantly regulate the voltage, or whether its's used to protect the Vcc voltage from rising too high,...
      04-13-2024, 06:32 AM
    • maralexbar
      How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
      by maralexbar
      I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
      It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
      If anyone knows how to force the external monitor as primary for Notebooks of those models
      11-02-2024, 09:18 AM
      09-06-2024, 05:27 AM
    • fmajbour
      Acer Nitro 5 model A515-51 keyboard problem
      by fmajbour
      I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
      Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
      i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
      I have check the keyboard connector on the mainboard every thing looks ok.
      Then i replaced the keyboard with new one ......same problem exact same keys problem.
      I need your advice if anyone face...
      11-13-2023, 09:50 PM
    • ahmarzo
      Acer TMX314-51 laptop battery problem
      by ahmarzo
      I have acer laptop tmx314-51 with part no 6050A3020501.
      The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
      But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
      I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
      The schematic is not available...
      04-11-2025, 09:14 AM
