Need Help with ceramic capacitors
+ More Options
Posts
  • elbtax
    • Apr 2008
    • 59
    I have two ceramic capacitors located near the power fet on a psu board that are craced and black looking on the top. The values are as follows:
    47J, 1kv & 12J, 1kv.
    I found one on Mouser but can't find the other. No results on Digi-Key. I
    would like to find them on DK as i am building my order for some fuses, and aluminum caps. Any help would be greatly appreciated.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Need Help with ceramic capacitors
    A tutorial can be found here'
    For the parts you have, they are respectively 47pF and 12pF, 5%, 1 KV
    Digikey part numbers are 445-2774-ND and 445-2781-ND.
    PlainBill
    • elbtax
      • Apr 2008
      • 59
      Thanks PB. I knew they were PF but i quoted exactly what is on the disc so there would be no mistakes. I like using Digi-Key but was getting no results when i typed in the part #. Not so on Mouser. Brought up the 47pf right off. Figured i would ask the experts hoping you would chime in. Mostly i just read the forums and have no input. I bow to others expertise.
      What ever happened to Dave Max?? Anyway, thanks again.....
      • spleenharvester
        Ceramic capacitors/resistors - do suppliers matter?
        by spleenharvester
        I want to buy one of those SMD component books so I don't have to spend as much time searching my scrap boards for what I need, specifically ceramic caps and resistors as they seem to be what I spend most of my time replacing. But the only ones I can find are no name brands. Does manufacturer matter as much for SMD parts as it does with electrolytics or is the generic stuff likely to be fine?
        05-01-2025, 05:34 PM
      • samtron786
        Ceramic capacitors half short circuit or full short circuit?
        by samtron786
        Hello
        two small ceramic capacitors with values 040. Can you tell me
        whether they are half short circuit or full short circuit?
        Thank you
        01-07-2024, 05:20 AM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
