Viewsonic VX910
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic VX910
    Originally posted by ajsemtb
    What are the fuses on this board? And to clarify, the transistors are are mounted to the heat sink?
    Fuses are marked with the letter F. Some picofuses are PF. For example, F100 or PF701.
    Transistors are marked with the letter Q. Transistors may be mounted to a heat sink.
    Do caps get hot?
    Caps can get hot. If they sit next to transistors and the heat flow is directed towards the caps, they will get hot and eventually die from heat and drying out.
    --- begin sig file ---
    --- end sig file ---
    • ajsemtb
      • Jul 2010
      • 79
      Re: Viewsonic VX910
      I'm went and looked at digikey for the transistors, and theres 6 different ones in the listings... Simple question, 120@500mV,2A gain or 82@500mV,2A gain?
      http://search.digikey.com/scripts/Dk...672+&x=20&y=13
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Viewsonic VX910
        Post a pic of the part that you are trying to replace. Posting pic guideline is at
        https://www.badcaps.net/forum/showthread.php?t=1868
          master hoarder
          • May 2008
          • 12175
          Re: Viewsonic VX910
          Also, looking at this board a little closer, I'm thinking these caps have already been replaced once. Well, the Xicon ones anyway.
          Xicon? Are they blue or light blue by any chance? If so, perhaps someone has recapped it indeed (with the wrong type of caps, that is). If I'm not mistaken, Radio Shack sells those Xicon caps - and they are definitely not suitable for monitor repair.
          • ajsemtb
            • Jul 2010
            • 79
            Re: Viewsonic VX910
            Yes they are blue and the 35v ones instead of the 25v ones I've been reading about.
            And RetiredCaps, I don't have access to a camera right now, however, in the 5th posting of this thread are pics from PlainBill with the transistors boxed in Red. Those are the ones to which I'm referring. Also, I did a test on the transitors that are attached directly to the heat sink, and I'm not sure which leg is actually which, but number 1-2-3 from right to left when upside down I'm getting these ohm readings:
            1-2 the number starts at 1k and starts climbing, and doesn't stop
            1-3 .1ohms
            2-3 is 4.7m and counting down...
            Honestly, I have no idea what his means.. LOL
            1-2 15.71m and counting down
            1-3 9.05k
            2-3 14.94k and counting down
            Also, I found the fuse, it was heatshrinked in black but I'm getting a reading of .2 to .1 ohms on it as well.
            https://www.badcaps.net/forum/attach...1&d=1280705628
            https://www.badcaps.net/forum/attach...1&d=1280705635
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Re: Viewsonic VX910
              1-3 .1ohms
              If pin1-3 on the transistor reads 0.1 ohms when it is out of circuit, it is definitely shorted (bad).
              The fuse is okay at 0.1 or 0.2 ohms. Some multimeters have a lower resistance for their probes.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Re: Viewsonic VX910
                Originally posted by retiredcaps
                I like the soldering videos by Curious Inventer on youtube.com.
                +1
                I finally didn't feel like I had to guess!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • ajsemtb
                  • Jul 2010
                  • 79
                  #28
                  Re: Viewsonic VX910
                  Ok, well I'm sorry again, but I didn't remove it from the circuit... I thought I could test these still installed to the board. :/ SO, this all being said, which caps do I need to buy, and when I type in the search engine at the digikey or mouser or whatever the other one was, there are 600 options that all say the same thing for different prices. What specifically should I buy for caps and the tiny transistors on the bottom of the board? What has been used in this installation before and has worked? The parts range from .29 to 2.89 which is a heck of a swing, and I would like to do this repair for less than buying a new power supply board.
                  Regarding the transistors mounted to the heat sinks, I'll remove them tomorrow and retest and post results.
                  Thanks again for all your help, I'm learning a lot as we go along.
                  Also, I have an Insignia 32 lcd model# NS-32LCD that has died. It too has a common problem with caps going bad on the power supply board, and again, mine aren't bulged. Which doesn't mean they aren't bad, but I honestly care more about getting my tv working again than this monitor at this exact moment only because I have 2 22" monitors another 19" and my laptop monitor making up my array, this particular monitor just went out, and I replaced it. BUT my TV not working sucks way more... LOL I have searched these threads, but don't see the Insignia come up, but I'm too new to start a new thread, and I don't want to hijack this thread, so I'm trying to use my experience from fixing the monitor before I tackle my TV.
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Re: Viewsonic VX910
                    Not only are they not suitable for monitor repair Xicon's light blue GP caps are 85C rated. Only their radioactive green GP caps are 105C rated and even those aren't suitable since they're GP.
                    Definitely a Radioshack special you've got there.
                    When measuring the transistors be sure to use the diode check function on the meter and not the resistance function. You're testing for voltage drop not resistance.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #30
                      Re: Viewsonic VX910
                      You can test transistors in circuit, but sometimes depending on how they are laid out, the results may not be 100% accurate so you need to remove them and test them out of circuit.
                      You need to make a list of the uF V, height and diameter of each capacitor and then follow PlainBill's instructions at
                      https://www.badcaps.net/forum/showpo...33&postcount=2
                      There is no "standard" list because each board can be a different revision and have different cap values (hence the request for pictures). Panasonic FM or FC caps are good low ESR choices.
                      My board "looks like" someone else may be a false sense of security. It is always better to make sure by reading the values of the caps on your own board.
                      Once you compile a list, some members here can verify.
                      • ajsemtb
                        • Jul 2010
                        • 79
                        #31
                        Re: Viewsonic VX910
                        Ok, well I ordered new caps (all except the very big one...probably come back to bite me but...) new transistors that flush mount the bottom, and a couple diodes that were mentioned that go out. All in all $12 including shipping. I ordered panasonic mainly FM but the little one was an FC. I'll update and let you all know how the repair goes.
                        • ajsemtb
                          • Jul 2010
                          • 79
                          #32
                          Re: Viewsonic VX910
                          Update, it didn't work... I recapped the 4 "main" ones, the 470uFs and the 330uFs. I didn't replace the really big one or the tiny one right next to the big one. I replaced the tiny transitors on the bottom. There is a difference now, as the screen at least flickers ever 2 seconds when the light blinks now. That is new. I hear a clicking each time it tris to turn on though. I heard it before also, when the ps was on my bench I plugged it in and heard a clicking as it cycled through.
                          When I installed the transitors, I tested them compared to the pair that I think work, and they gave me the same readings. Well, after my test, I think they shorted again, because for voltage they were at .270 and now they are .023. So that sucks. Luckily I bought 4 to do all of them, but Im pretty sure its just the one side thats fried. SO, that being said, besides replacing the only 2 caps I didn't change yet, what else could I test? what would be clicking?
                          Also, after my bench test, the really big Cap is holding voltage. 12v and with my DMM on it it slowly goes down. Its been almost 10 minutes and I'm at 7v and counting... Any thoughts?
                          I think someone said to change out the 2 ceramic capacitors... What are those and what do they look like? Also, what is the white "square" thingy on the top of the board that has a matching one on the other side?
                          Thanks again for all your help. I'm not giving up yet...
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Re: Viewsonic VX910
                            The little cap is sometimes called a startup/run cap. It is usually in the 1uF/2uF 50V range or something like 22uF/50V. That cap doesn't have to bloat to be bad.
                            The clicking sound maybe the SMPS trying to startup. The little cap helps the SMPS startup.
                            Which leads to ... replace the little cap. That may solve the problem?
                            If the transistors are shorted again, resolder all the transformer pins (the 2 yellow things marked with T). Remove the old solder and resolder with fresh solder.
                            edit: Here is PlainBill talking about the startup cap ...
                            https://www.badcaps.net/forum/showpo...97&postcount=2
                            • jetadm123
                              • 2169
                              #34
                              Re: Viewsonic VX910
                              Quote from ajsemtb: I think someone said to change out the 2 ceramic capacitors... What are those and what do they look like? Also, what is the white "square" thingy on the top of the board that has a matching one on the other side?
                              If you're talking about the "square" units wrapped in yellow tape, those are the inverter transformers, which generate the high voltages required to light the backlights.
                              As for the two capacitors: I think what the person is talking about are the brown (or dark orange) caps directly below each inverter transformer. From memory, I think they are polypropolene caps stamped "154" and rated at 250volts. These caps have a tendency to fail and might be the cause of your problem.
                              • ajsemtb
                                • Jul 2010
                                • 79
                                #35
                                Re: Viewsonic VX910
                                Ok, well I'll order those, and I guess I'll bite the $2 bullet and buy the big capacitor also LOL and before replacing the transistors again. Is there any chance that the transformer is dead? Are those replacable easy or cost effective? Thanks again for all the tips.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Re: Viewsonic VX910
                                  The transformer converts the low voltage into high voltage to drive the ccfls. These can be bad. You can test for open windings on the transformer by (with power off and unplugged)
                                  a) Number the pins on the transformers anyway you like
                                  b) black probe on pin 1, red on pin 2 - record ohm
                                  c) black probe on pin 1, red on pin 3 - record ohm
                                  d) black probe on pin 1, red on pin 4 - record ohm
                                  e) etc
                                  f) black probe on pin 1, red on pin last - record ohm
                                  g) black probe on pin 2, red on pin 3 - record ohm
                                  h) black probe on pin 2, red on pin 4 - record ohm
                                  i) etc
                                  j) black probe on pin 2, red on pin last - record ohm
                                  k) black probe on pin 3, red on pin 4 - record ohm
                                  l) etc
                                  m) finally, black probe on pin last-1, red on pin last - record ohm
                                  I'm guessing the secondaries should read 950 ohm (this will vary for different transformers). The primaries should read 1.3 ohm. Some will be 0L. If one secondary is 950ohm and the other is 750ohm, that would indicate a problem.
                                  This test is not exhaustive as it does not detect all faults. For that, you will need a ring tester to test the coils.
                                  • ajsemtb
                                    • Jul 2010
                                    • 79
                                    #37
                                    Re: Viewsonic VX910
                                    Retired, I did that test on the transformer still installed, the best I could, and the one transformer T2 tests with 745 ohms, which I've read somewhere is supposed to be right. This one is testing 55.9 ohms. But thats across the whole "part" of this cluster. If I test the ohms of the transistors I replaced, its the same, if I put my tester in points R22 and R18 it get the same, so I'm not sure the transformer is bad per se... Do I need to start taking this thing apart piece by piece and testing them all out of the board?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      Re: Viewsonic VX910
                                      Maybe this video will help "Testing for Faulty Inverter Transformers Tutorial"
                                      http://www.youtube.com/watch?v=eNuGWBPRGKA
                                      • ajsemtb
                                        • Jul 2010
                                        • 79
                                        #39
                                        Re: Viewsonic VX910
                                        I'm trying to find the part number on Digikey for the C24 poly cap. In the service manual there are 2 optional parts: 1) cap, polyproplene, 154, J, 250V, 13L*6.5T*12H*10F,,MPP-154J0250DB110, HJC and 2) cap. polyester, 0.15uF, K, 160V, 13L*4T*9H*10F, BOX, R75GF3150, ARCO Can someone please let me know what the correct part is, because one is 250V the other is 160V is that AC or DC why is 1 154 and the other .15uF. ??? !!! I think its part number 495-1201-ND at Digikey, but it doesn't look like this part. thanks, I want to order parts tomorrow. ordering these, the resistor located in R320 and R112, and the ceramic caps at C26, C27.
                                        • jetadm123
                                          • 2169
                                          #40
                                          Re: Viewsonic VX910
                                          Hopefully, this makes sense. 154 and .15uf are the same. The "154" is capacitor code for:
                                          15 is the cap value followed by the multiplier (in this case 4 zeros) and the value is in pf. Therefore, we have:
                                          150,000pf = 150nf = .15uf
                                          J and K are the tolerances: +/- 5% and +/- 10%
                                          Not sure why there's a difference in voltages of 250 vs 160
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
                                            HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
