Daytek F19AH
+ More Options
Posts
  • jetadm123
    • 2169
    #41
    Re: Daytek F19AH
    Okay, it looks like Q102 is a general purpose NPN transistor, PMBS3904. Spec sheet below. Pin 5 of IC101 is basically used to shut down the power supply in case of over temperature. Since a thermistor is not being used here like it is in the pdf schematic, the temperature function is not being used. From the IC101 specs, it looks like pin 5 has to be held at above .65 Volts to prevent power supply shutdown. Once it drops below .62 volts the supply will shutdown. With the monitor on can you measure the voltage of pin 5. If it's going below and above .62V, shut off the monitor and perform a short circuit check on Q102 using the numbering config on the spec sheet and retiredcaps instructions at this link:
    https://www.badcaps.net/forum/showth...ng+transistors
    I'm off to bed.
    • PlainBill
      • Feb 2009
      • 7034
      Re: Daytek F19AH
      I've got a wild idea. With the boards hooked up the same way they were for the other voltage tests but with power off, measure the resistance across C122. It's on the back side of the board, close to the output connector.
      PlainBill
      • UserName666
        • Aug 2010
        • 76
        #43
        Re: Daytek F19AH
        Originally posted by retiredcaps
        To test for shorts on a transistor, test the following with ohms.
        pin 1 to pin 2
        pin 1 to pin 3
        pin 2 to pin 3
        If anything reads less than 50 ohms, it suggest a possible short.
        lol I had a feeling it was gonna come to something like this. Can these resistance checks be made while it is still in the board?? I have a good feeling I won't be able to solder that small.
        I'm off to bed.
        Re: Testing with monitor on for the 5 volts can't happen as it won't power up at all.
        PlainBill
        I have been doing the tests with the power board out from the rest of the monitor. Got tired of installing it/removing it. I was gonna wait for the transformer click to stop before hooking it all back up.
        Resistance across C122 in circuit with no voltage with power board removed from monitor is 25.9ohms one way and 27.1ohms reversing the leads.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          Re: Daytek F19AH
          Yes, you can do the tests in circuit. If the readings look suspicious, then you will have to desolder to be 100% sure.
          PS. I'm planning to update the guide in a few weeks with some of the feedback I have gotten.
          --- begin sig file ---
          --- end sig file ---
          • UserName666
            • Aug 2010
            • 76
            #45
            Re: Daytek F19AH
            Q102 reads as follows according to the pic I added (In circuit - No live power)
            1-2 = 11.80 Mohms
            1-3 = 9.97 Kohms
            2-3 = 11.77 Mohms
            • PlainBill
              • Feb 2009
              • 7034
              Re: Daytek F19AH
              OK, scratch that idea. I was thinking in terms of a short (or low resistance) across the output.
              PlainBill
              • jetadm123
                • 2169
                #47
                Re: Daytek F19AH
                One thing I should have mentioned right of the top is this monitor was used in a poorly ventilated cabinet and all of the sudden just went out and you could faintly smell burnt electronics. The poorly ventilated cabinet makes me think this was an overheat issue.
                Since you mentioned that you got a whiff of the "magic smoke", can you please post two of your cool pictures of the entire board, both top and bottom.
                • UserName666
                  • Aug 2010
                  • 76
                  #48
                  Re: Daytek F19AH
                  Done. These are the highest megagpixel setting my camera can do.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #49
                    Re: Daytek F19AH
                    There is a possiblity that acer 1914bm uses the same power board as this Daytek. You can search acer 1914bm service manual to see if there is one with schematics.
                    I got this idea from the 0509d1248 designation (right above the li shin) on the board.
                    • jetadm123
                      • 2169
                      #50
                      Re: Daytek F19AH
                      This is sort of a weird design where there's only one dual diode pak (Q1 in the pdf file) that supplies 12 volts for everything. Normally, you have two separate paks, one to supply 12V to the inverter and the other to supply 5V to the logic board and LCD panel. Looking at your photo, I believe the diode pak on your board is the one mounted to the heatsink at the left. It usually has a symbol of two diodes connected head to head stamped on it. Please supply the part # and with power off try performing a short circuit check on it in circuit.
                      • UserName666
                        • Aug 2010
                        • 76
                        #51
                        Re: Daytek F19AH
                        I should have asked first but I hope these tests can be done in-board because thats the way I did it.
                        The one circled in YELLOW on the heatsink by the filter cap is:
                        1-2 = Starts at 41 Kohm rises to about 400 Kohm then jumps to about 1.2 Mohm and keeps rising. Reverse leads 0 Mohms
                        1-3 = 86.1 kohm reverse leads 81.2 Kohm
                        2-3 Starts at 18.5 Mohms and drops. I stopped testing at 12 Mohms. Reverse leads 0 Mohms
                        The one circled in RED by the cluster of caps is:
                        1-2 = 27.1 ohms reverse leads 26 ohms
                        1-3 = 00.3 ohms reverse leads 00.3 ohms
                        2-3 = 27.1 ohms reverse leads 26 ohms
                        Part #'s are visible in pic 2 & 3. I didn't know if that was a letter F or a company logo.
                        • UserName666
                          • Aug 2010
                          • 76
                          #52
                          Re: Daytek F19AH
                          As for the service manual I found one for a 1914 but not 1914bm specific. The powerboard is not a match.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #53
                            Re: Daytek F19AH
                            0.3 and 27 ohms suggests this is shorted or bad.
                            edit: Datasheet is at
                            You will have to desolder this component and test out of circuit to verify it is shorted.
                            F, I think, is Fairchild.
                            • UserName666
                              • Aug 2010
                              • 76
                              #54
                              Re: Daytek F19AH
                              OK & ya know what...The one with 00.3 ohm reading (red) is DIRECTLY BESIDE the capacitor that was bloated by like less than 2mm. I'll get to the desoldering in a little bit and get back w/ he readings
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #55
                                Re: Daytek F19AH
                                Is it possible that your replacement capacitor soldering is touching this component? That would cause false readings.
                                • UserName666
                                  • Aug 2010
                                  • 76
                                  #56
                                  Re: Daytek F19AH
                                  No I meant 2mm close on the top of the board but looking underneath the middle pin of the rectifier IS connected to the cap that was bloated.
                                  Rectifier in blue and the capacitor that bloated is in red.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #57
                                    Re: Daytek F19AH
                                    Okay, soldering all looks good. No bridges. I suggest you desolder the component and test out of circuit.
                                    If it is bad, a replacement is available at digikey for just over $1.
                                    • UserName666
                                      • Aug 2010
                                      • 76
                                      #58
                                      Re: Daytek F19AH
                                      OK I pulled the STPS10H100CT from the board and it reads:
                                      1-2 = Starts at 30 Mohm and continuously drops rapidly-reverse leads- Starts at 32 Kohm and drops slowly.
                                      1-3 = Starts at 26 Mohm and drops rapidly -reverse leads- Starts at 36Mohm and drops rapidly
                                      2-3 = Starts at 30 Mohm and drops rapidly -reverse leads- 40.1 Kohm (steady)
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #59
                                        Re: Daytek F19AH
                                        There is another component right by this STPS10H100CT. I can't see it from the angle of the pictures, but it has 02 and the end. I think it is a diode D102?
                                        1) what is it?
                                        2) if it is a diode, do a diode check with your multimeter. This component could be shorted? This would explain why pin 1-3 on the STPS10H100CT in circuit, but measure non shorted out of circuit.
                                        STPS10H100CT is good out of circuit from your measurements.
                                        • UserName666
                                          • Aug 2010
                                          • 76
                                          #60
                                          Re: Daytek F19AH
                                          I'm not sure what it is but it is labeled L102. D108 is what I just took out.
                                          This boards also has an L107,L105 and L108 surrounding the Filter cap. Not that has anything to do with anything. Just not sure what the "L" is.
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • korben_dallas
                                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                            by korben_dallas
                                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                            MY QUESTION:
                                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                            02-14-2024, 12:23 AM
                                          • Yanleb
                                            LG 60PK550 Logic Control Board EBR63450301
                                            by Yanleb
                                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                                            C57: 3.30V
                                            C61:...
                                            07-20-2023, 12:38 AM
                                          • mferna14
                                            Logic Board 820-00840-A Missing EDP_BKLT_EN
                                            by mferna14
                                            Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                                            07-10-2024, 05:18 PM
                                          • mferna14
                                            Logic Board 820-01987-A missing PP3V3_S5
                                            by mferna14
                                            Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                                            06-07-2025, 05:07 PM
