iMac G5 inverter question
  • Jon B
    • Nov 2009
    • 30
    Hello all
    Does anyone know how to run an iMac G5 back light inverter off of an external power supply?
    I am trying to setup a LCD panel for testing logic boards. I don't want to have to connect it to the inverter powered by the logic board.
    I guess I need a pin-out for the inverter and how to handle the dimming circuit.
    Please let me know if this would be better posted under another topic.
    Thanks for any help pointing me in the right direction.
  • caseyjay_48
    Sony KDL-46BX450 Inverter Troubleshoot Logic
    by caseyjay_48
    I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
    I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
    09-23-2022, 08:08 PM
  • howardc64
    Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
    by howardc64
    Problem
    Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
    Model & Board Pics
    Conflicting Spec
    Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
    https://www.shopjimmy.com/vizio-gj-2k1...
    10-10-2024, 01:16 PM
  • reessi
    Imac A1312 - Blown Diode, Need Inverter Schematic?
    by reessi
    iMac 27-Inch "Core i7" 3.4 (Mid-2011):
    First off I have the Imac Schematic but only for the mainboard, does anyone have the inverter one or a similiar one from another for better understanding?
    Searched all over for one!
    All voltages to the Inverter are correct:
    (12v in, 3.3v Enable and PWM Approx 3.0v).
    Output was 12v and moved a little but Inverter was obviously cutting off as D1 was SHORTED.
    After replacing this the IMAC works for 1 week exactly and dies again. When working the output was correct...
    12-04-2020, 06:58 AM
  • jpreza
    iMac 4K 2019 Logic Board schematic
    by jpreza
    Hey guys,
    Looking for schematics for an iMac 4k 2019 model. For the life of me, I can't figure out why the display will not work. Everything is connected correctly, I don't see any caps or resistors that are damaged. I even swapped the display from another iMac 4k 2019 model to test it, and that display won't work either.
    There are 5 diagnostic LEDs and only 4 light up. The last one does not.
    Any help with schematics would be awesome!
    JP
    04-13-2023, 02:23 PM
  • GlobalBrian
    820-02009-A Logic Board for iMac (24-inch, M1, 2021, Four ports)
    by GlobalBrian
    Anyone have this schematic and/or boardview?
    12-27-2024, 12:27 AM
