Dell 1703fps dark screen but power lt steady
+ More Options
Posts
  • kturnerga
    • Apr 2010
    • 20
    Hi!
    I found a Dell 1703FPS which lights up but gives a darkened screen. I took it apart and it has a BN41-00296B powr supply and a BN44-00073 inverter board. Some say it is the inverter board (if not the backlight ccfl) and some say the inverter kicks off if the power supply gives it not enough juice. I saw no swollen caps on the boards though I smelled an electrolytic smell on the power board.
    I hope to gosh it isn't the inverter or the transformers on the inverter. If so I guess I've got to fix my free monitor for 40.00 (or less; it depends). If anyone has had experiences with this monitor post what you found out.
    KT
  • trwilson70
    • Mar 2010
    • 69
    Re: Dell 1703fps dark screen but power lt steady
    Just completed fixing one. The inverter transformers appeared to have overheated - waxy substance all around. I had another inverter from a smaller monitor for testing -everything looked good. I didn't want to pay $40+ for an inverter. Found someone selling a complete 1703FPs on eBay - good except the screen was damaged. Paid $20.50 shipped - swapped the inverter and now it looks great. Just to be safe I recapped power board.
    • mathog
      • Mar 2010
      • 2655
      Are you talking about the black stuff in this image?
      https://www.badcaps.net/forum/attach...chmentid=12151
      That glop is on all of them. It's probably there to suppress vibration.
      • trwilson70
        • Mar 2010
        • 69
        My inverter was different - had a total of 4 transformers. They had a waxy ooze - almost clear, not black. That looks too uniform, but without seeing it's hard to tell. Have you checked power to the inverter?
        • mcfischer
          • Dec 2008
          • 12
          The inverter board you have is made by Lien Chang and is notorious for frying a transformer, disabling half the lamps. You can often see the black soot at the inside edge of the transformer, between the lamp sockets. They use a hard black "potting" material to insulate the secondary voltage that makes removal difficult unless you have a dremel grinder.
          I have not fould a source for the transformer. I do rob them from other Lien Chang inverters like one used in some 15" HP 1530s.
          Mike
          • mathog
            • Mar 2010
            • 2655
            I do have a (generic) Dremel, but would be mighty afraid to use it on a circuit board. Sure, it would cut through the black gunk, and then the top traces, and the board underneath. Seems like removing just the potting material would take a steadier hand than mine.
            • kturnerga
              • Apr 2010
              • 20
              mathog do like I plan to; wait until another monitor with a total power outage or a busted panel comes forth replete with a LI-2070 inverter inside. I found that the material is very hard and that was all it took to decide for me. Put out a saved search alert on Ebay for the following models you might solve your issues:
              http://www.lcdrepair.us/1703fps-inverter.html
              Unless you have a darned good screen don't fiddle with getting an inverter for 30-40.00 when you can do trash surfing or pay a few bucks in parts value.
              • PlainBill
                • Feb 2009
                • 7034
                A valid point to keep in mind. A 22", 24" or larger wide screen monitor from a reputable manufacturer is expensive and well worth preserving. A 17" monitor from a not so reputable manufacturer may well be worth spending $10 to repair. But for the price of an aftermarket inverter you should be able to buy a good quality repaired working 19" monitor. My last Craigslist run netted me a 17" Dell, a 19" wide screen Samsung, and a 22" wide screen Proview without a stand. It cost me $.44 to prove the Dell is unrepairable (dead video processor), and about $20.00 in parts to recap the Proview, the Samsung, and a 17" Emprex from a previous haul.
                We all like the thrill of repairing a dead monitor and keeping something out of the landfill. But sometimes it is best to write them off as a parts source.
                PlainBill
                • kturnerga
                  • Apr 2010
                  • 20
                  Plainbill I agree. I can't have a monitor bigger than 17 in but if I can get hold of a monitor with the inverter in question, and for 10 or 20.00 (or less) I think it's money well spent. I lucked up on fixing two monitors with the power-off issue so I may have the big-head syndrome going.
                  Good luck on the cataract surgery. It is no fun losing your sight even for a moment or losing part of your sight.
                  • HTR-Informatique
                    Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                    by HTR-Informatique
                    YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                    I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                    On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                    I also changed the screen because the PC fell and the screen was broken.
                    I changed the battery with a new and original battery.
                    I also had corrosion/oxidation on the...
                    02-09-2025, 06:51 AM
                  • Swedishpower
                    Dell G3 15 3500 black screen
                    by Swedishpower
                    Hello
                    I have search everywhere for a solution for my problem, but cant find it anywhere.
                    When I was away to trow some garbage i always look in the electronic bin.
                    and this time i find a laptop.
                    Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                    the lamp for charmig is white.
                    Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                    but no Dell logo.
                    I tryed with a hdmi cable to another screen, still black.
                    I started to search solution and tryed...
                    07-06-2025, 06:18 AM
                  • jake-b
                    dell e6540 boots to black screen (no dell logo)
                    by jake-b
                    good morning all,
                    i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                    01-08-2024, 10:29 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • hcinne
                    Dell G15 ryzen edition black screen 2 amber 1 white
                    by hcinne
                    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                    07-23-2024, 07:56 AM
