Tyris powers off
  • mathog
    • Mar 2010
    • 2655
    Tyris powers off
    My son tells me his 17" Tyris (marked F179, also T701DB) powers off to dead "every couple of days" but usually "comes back on when I whack it". First I heard about this was last night when it would no longer respond to being beaten. The thing is on at least 8 hours a day. The Tyris works fine for me, but I didn't wait 16 hours for a failure. Swapped it out for a previously repaired Acer, and today opened the Tyris. Inside found PS board DCAC40A4 (UP0401UB12Q07) with video board GBM Group LM1X02N_MB Ver 1.0 P/N MLM00M10110). (What is it with every board having two types of part numbers????) The first board has all LTEC caps and the latter is all Capxon, but none of them look bad on either board.
    From the symptoms it sounds like it might be a cracked solder joint, probably on the PS, will pull that board and resolder it when I have time. Is it worth replacing the caps on either board while it is disassembled? I don't know much about LTECs but the CapXon's have a pretty poor reputation. For the video card the CapXons are 7X (47uF 16V), 2X (100uF 16V), 2X (470uF 16V), 1X (220uF 16V). For the PS board the LTECs are 2X (680uF 16V), 1X (220uF 25V), 1X (10uF 50V).
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Tyris powers off
    I've found LTECs in PSUs specifically in PS2s and Xboxes (Delta brand PSUs) and I haven't seen one bulge. The original xboxes ran pretty hot too.
    I have them in my Antec Earthwatts on the less stressed rails and I'm not worried.
    But since you're in there and you have easy access for replacement it wouldn't hurt to replace both brands. The Crapxons are a definite though.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
