Samsung CJG5 32 JOG button stopped working,OMG Samsung!!
  • paparazzo79
    • Dec 2018
    • 299
    • Bosnia
    On my monitor JOG button stopped to work.
    I mean I had issues before with it when tilting it upwards it doesn't accept command sometimes
    Now when pressing the button it should turn off the monitor from stand by mode,but it doesn't do anything.
    God damn Samsung,make me wish never to buy anything from Samsung anymore.
    I googled for solution and found that the issue is even with premium models.
    What can I do?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8253
    Re: Samsung CJG5 32 JOG button stopped working,OMG Samsung!!
    Open up the monitor and fix / replace the jog button.
    • paparazzo79
      • Dec 2018
      • 299
      • Bosnia
      Great advice...don't know what else to say...
        • 21304
        Theres a few suggested fixes at a reddit post,they might only be temporary though
        https://www.reddit.com/r/Monitors/co...n_not_working/
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8253
          How else you'd want to fix it? Without opening and looking at it what the problem actually is? Is it gooped up, is it mechanically broken or what? If you want a precise answer, you have to explain your problem in detail, plus don't forget to attach pictures.
          • paparazzo79
            • Dec 2018
            • 299
            • Bosnia
            Ok, let me try to do a video to explain in details.
              09-07-2024, 05:50 AM
              by momaka
              03-15-2023, 10:17 PM
            • glutton4punishment
              Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
              by glutton4punishment
              Samsung synchmaster 226BW.
              Before I replaced 5 caps, the screen was dim.
              Sometimes it wouldn't turn on.
              I opened it up, and found 4 bad caps in the pwr supply section.
              I unfortunately installee one backwards, i.e. wrong polarity.
              When I turned it on, I head a loud pop, and I quickly shut it off.
              The replaced caps are 3 860uF 25V's, and 1 330u 35V.
              One of the 860uF blew.
              I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
              03-18-2023, 12:49 PM
              09-06-2024, 11:40 PM
