Dell E176FPb No Data found logo
  • andy smethurst
    • 49
    This Dell monitor, with power only connected, as usual displays the data cable disconected,floating logo. When the data cable is attached,the power led turns amber, and the display (or logo) shuts down. I dont think this is a power problem as I have come accross this problem in other types of monitor but never resolved them, as the data board is quite a pain to diognose.
    I would be greatful for some tips, if someone had previouse experience with this problem or data board.
    Regards: Andy.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E176FPb No Data found logo
    Regards: Andy.
    Check the voltage regulators on the logic card (data board). There have been several cases lately where the 1.8 Volt regulator started putting out too high a voltage and apparently damaged the processor chips inputs. Attach a picture if you need help identifying them.
    PlainBill
    • andy smethurst
      • 49
      Thanks for the advice P.B, I did check the 1.8v and 3.3v regulator along with other associated parts, and could find no wrong. These monitors are a pain to work on as both boards are mounted face first into a metal shroud that is then attached to the screen. This makes it difficult to disassemble and make the connections to safely add the power for testing. Still it had to be done for the process of elimination. I decided to roughly reassemble the unit to see if it worked, and it did. Sometimes just pulling all connectors and pluging them back, resolves some problems, but not very often. It worked this time ,and problem solved.
      Regards: Andy.
      • TheQuentincc
        Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
        by TheQuentincc
        I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
        06-26-2025, 01:44 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • ulysse31_revient
        dell P2412Hb logo disappears
        by ulysse31_revient
        Hi All,
        UPDATE: post was moved to new thread, so editing it ^^'
        I'm a totally new to electronic repair, I do play a bit with arduinos, 3d printers, esp32 ... but I'm generally more on the coding/software side for hobby ^^" my electronic skills do not go much further for now ^^'
        I decided to start doing some repair, just to avoid throwing things to trash ...
        Since I have a broken lcd monitor, I decided to try to get this thing to work for a start ^^"
        I have a dell P2412Hb, which seems to be similar setup than the one on this thread https:...
        09-04-2023, 07:22 AM
      • digtalhd
        Dell Inspiron 7490 Stuck on Dell Logo
        by digtalhd
        Hi!
        Anyone hepl me! My laptop stuck Dell logo after I clear ME.
        Dell Inspiron 7490
        S/N: 28760285127
        LA-H451P Rev: 1.0
        Thank!...
        11-13-2024, 10:17 PM
      • fredyjbi
        please help dell 5530 LA-J191P rev 1.0 (a00) stuck dell logo thank you
        by fredyjbi
        Please help Dell 5550 LA-J191P rev 1.0 (a00) stuck Dell logo, please help me clean this bios, the serial number paper has disappeared so I don't know what the serial number is, thank you...
        08-13-2024, 11:26 AM
