Re: WestingHouse L2210NW Will not power.
Now that I see how you numbered the pins (there is no right or wrong way), my number #1 suspicion is that this transformer is bad.
Your measurements on the secondary pins (pin 1, 2, 7, and 8)
black probe on pin 1, red on pin 2 - .872 ohms
black probe on pin 7, red on pin 8 - justs around from 1.121 to 1.580 ohms
If you watch the youtube video link I posted earlier, that transformer was out be a factor of 10x (950 ohm versus 9500 ohms).
Now you can desolder the transformer and retest out of circuit to make sure that no surrounding component are affecting the measurements (just like the video).
If the numbers are still not identical, the next problem is where to find a replacement and are you willing to pay probably $25 for a replacement?
edit: You can email
http://lcdparts.net/T.aspx
to see if they have a replacement that is not listed on their website. If they do have a replacement ask them for specifications specifically what is the resistance between the secondary pins.Last edited by retiredcaps; 08-23-2010, 05:17 PM.--- begin sig file ---
--- end sig file ---Comment
If 7 and 8 consistently show out of range on the 2k ohm scale, you have an open winding on the transformer.--- begin sig file ---
I'm decidedly old school, and find autoranging can lead to confusing readings. I'd set the DMM to the 20K ohm range and check the reading with the probes shorted together. After that, check from pin 1 to 2 and then from 7 to 8.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Both dmms give a reading of 0.7 ohms when probes are shorted together.
It will be interesting to see the 20km test results.--- begin sig file ---
My concern is the fact that the readings keep changing. IF this is operator error, that is one thing; eventually your technique will improve. But if it's an intermittent problem with the transformer or other component, it will be difficult to locate the source of the problem.
Okay, the transformer is okay. Yesterday the readings were pointing to an open winding on pin 7 and 8.
Let's move on. I suggest it is time to take a look at the CCFLs. This picture album shows what a bad CCFL looks like
http://s807.photobucket.com/albums/y...klight%20lamp/
Be very careful taking apart the CCFL assembly.
PS. You haven't answered yet re the flashlight test.--- begin sig file ---
ok so i have reassembled the monitor and turned it on. At first it worked for more then 2 seconds, about 2-3 mins then i turned it off and moved it and tried it again and it started doing the two second off again. i took a flashlight and tried to see if i could see anything on the screen and its completely black no images at all.Comment
It is possible that probing pin 7 and 8 has uncovered a poor solder joint. I suggest removing the old solder from pin 7 and 8 and putting in new fresh solder. A poor solder might explain the erratic readings on the multimeter? It is point #7 of
https://www.badcaps.net/forum/showthread.php?t=10419
That might also explain why it worked for 2 or 3 minutes until you moved it.
Question: Have you ever seen any pink hues in the last month of use? A pink hue is a sign of an aging CCFL drawing more and more power. The extra power draw will cause the inverter IC chip to shutdown the backlights.--- begin sig file ---
There should only be new solder on the joints i used a desoldering iron to remove all solder from the transformer before removing it, and i got this monitor broken it was brought in to my work for recycling so i dont know about the pink hue. i will disassemble the monitor again and re solder all the joints and ill check the ccfl's to see if they are bad.Comment
The only thing that I can think of right now is poor solder joints somewhere on the board or a bad CCFL.--- begin sig file ---
ok so new development i just plugged it in to test it all again with out doing anything to it. i just wanted to make sure everything was not working like it was before. this time i didnt get any power light and i did get a electrical burning smell. i took it apart and it smells like its coming from the other transformer. i did i reading on that one and i got nothing everything was out of range.Comment
Post a picture of the logic board. And don't put it inline. Just leave as attachment.--- begin sig file ---
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
