Samsung 193v backlight doesn't stay on
  • sceva
    • 196
    Re: Samsung 193v backlight doesn't stay on
    I used ccfl's that had been removed from another screen, so I could see the individual tubes and determine which bulbs were not lighting up. I connected these ccfls to all 4 connections and they would stay lit so I could easily tell which lamp wasn't lighting and therefore which transformer was bad.
    A couple of points if you aren't able to do the above test - you have to have all 4 connectors connected to ccfl's, or it will turn off. Try connecting 3 wires from the original lcd and one from the external lcd (always use the same connector on the external one - as it is possible that one of those tubes could be bad), and test it, noting if the external lamp came on. Then move the external lcd connection to the next connection, reconnect the original, and test again, doing this at all four connectors. Then you should be able to determine if one or more of the transformers are bad. I usually only had one bad per board, but occasionally there were two that were bad. Also check the board in the inverter area. If you have dark spots above the components labeled U2 -U4 it is possible they are damaged, and replacing the transformer will not solve the problem.
    After working on this model I ordered a Blue Ring Tester from Anatek and it is very nice for determining if a transformer is good or not.
      09-07-2024, 05:50 AM
    • C152Heavy
      by C152Heavy
      Summary for TL-DR readers:
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • sansanpartida
      Samsung QE82Q70RAT no backlight
      by sansanpartida
      Hi everyone!
      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
      My issue: No backlight.
      Model: QE82Q70RAT
      Type No: QE82Q70RAT
      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
      So hopefully, I can fix this cheaper.
      05-22-2024, 06:56 AM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
