What is this part.....
  • PlainBill
    • Feb 2009
    • 7034
    Re: What is this part.....
    Originally posted by Welchs101
    In an early post someone suggested a replacement "Inrush current limiter" but the suggested replacement i think has a resistance of 12ohm........i measured ~ 9ohms on the one that i want to replace.
    So it got me to thinking ..........what do i need.
    The marking (see original pic) is SCK083
    This web site has sck type products but to be honest i am not sure what i need. I would like to order something from digikey if possible. Any ideas?
    I'm going to make a SWAG that the number on the part shows the critical, non-obvious information. There is no point in putting the diameter on the part - that can be readily measured. The 08 could indicate the cold resistance - 8 ohms, while the 3 indicates the current at 25°C - 0.3 A. They don't seem to spec the maximum current. but I would expect the monitor to pull something under 100 watts, so let's say 1 Amp.
    The closest match at Digikey would be 317-1149-ND. Or you could try using one from an unrepairable monitor.
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      Hi Bill,
      Using this link .......i thought the resistance was 30ohms.......
      Resistane / Max Cur. / ~ R of Max cur. / Dis. Coef. / Thermal Constant
      30 / 1 / 1.022 / 11 / 30 for the MF72-30D9
      8 / 1 / 0.539 / 9 / 28 for the MF72-8D7
      Now i could be wrong .......totally wrong. The link might not be right.....
      What do you think?
      • PlainBill
        • Feb 2009
        • 7034
        Hi Bill,
        What do you think?
        I don't know. The problem is they use the SCK series identifier and a 3 digit code. Nowhere do the correlate the 3 digit code to a part number.
        I just looked at a couple of 19" monitors I have here. The maximum current on one is .9A, on the other it's 1.5A. That calls for a maximum current of at least two amps.
        DUH!!! Email them and ask them to explain how SCK 083 correlates to the maximum current and no load resistance.
        PlainBill
        • Welchs101
          • Sep 2008
          • 979
          I just did........i will let you know what they say.
          • Welchs101
            • Sep 2008
            • 979
            ok...never got a response from them.
            But i did a little checking again and i am glad i did.
            The SCK083 .....the resistance is not 30ohms.
            Ok let me start over........originally i had found this link
            From the above link i thought the Resistance was 30hms. But then i found another link which i tend to believe more.
            Here the resistance is 8ohms. Recall that when i physically measure the device i get 9ohms.
            Ok so my question is i have a replacement bridge rectifier and the only SCK i have is SCK035 which measures about 4.7ohms. Can i use the SCK035 instead of the SC083?
            Using the SCK035 will not cause a problem will it?
            • Welchs101
              • Sep 2008
              • 979
              i copied the data from the spec see enclosed pic.........
              • Welchs101
                • Sep 2008
                • 979
                Just wondering if i use SCK035 (since i dont have a SCK083) ....does anyone see any problems with this.
                This thermistor came out of a power supply from an LCD monitor.
                • PlainBill
                  • Feb 2009
                  • 7034
                  As long as the monitor has roughly the same power rating and the bridge has the same current rating, I wouldn't worry.
                  PlainBill
                  • Welchs101
                    • Sep 2008
                    • 979
                    Hi Bill,
                    thanks. wanted to update you.
                    I put the other thermistor in and when i went to put in the spare bridge rectifier (replacement from another unit) the leads on the recitifier were too large so i cant use it.........
                    guess i will just have to order a replacement rectifier.
                    thanks for your hellp.
                    • Toasty
                      • Jul 2007
                      • 4171
                      #30
                      Don't be overly concerned with the cold resistance of the NTC thermistor. It drops to zero nearly instantly as the unit comes on. As long is of the same or higher power rating or from a similar unit you'll be fine.
                      Use a fine drill bit and open the holes to accept the bridge rectifier leads.
                      veritas odium parit
                      • Welchs101
                        • Sep 2008
                        • 979
                        I am going to order a new bridge rectifier.
                        Someone had suggested i use this one
                        http://search.digikey.com/scripts/Dk...%2F51&x=29&y=9
                        But since i am going to "piggy-back" on a order that my friend is placing and they are using Newark not digikey (i usually use digikey) that part that was recommended above is available through newark but you have to order 600 at time. I found this one on newark...........would it be ok
                        http://www.newark.com/multicomp/kbl4...83?Ntt=01P3583
                        Recall the orginal part i am replacing D2SB....which is i think (based on inputs from badcaps forum) a 1.5A 600V.
                        • Welchs101
                          • Sep 2008
                          • 979
                          Just wanted to double check before i buy
                          http://www.newark.com/multicomp/kbl...583?Ntt=01P3583
                          would the above rectifier be ok?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            At this point you should be able to answer the question yourself.
                            1. Will it fit?
                            2. Is the voltage rating high enough?
                            3. Is the current rating high enough?
                            PlainBill
                            • Welchs101
                              • Sep 2008
                              • 979
                              hi Bill,
                              I compared a few parameters like
                              1) If
                              2) VRRm
                              3) VRMS
                              4) VF
                              5) typical thermal resistance
                              and they are the same for both for the above parameters.
                              Whats different between the two:
                              IR: DIgikey part: IR = 5uA to 1mA, Newark part: 10uA to 500uA
                              Operating temp: Max for digikey part is 150C, Newark part is 125C
                              what i was not sure of is are these differences significant enough not to get the newark part. I think its not that significant but just wanted to be sure.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                hi Bill,
                                1) If
                                2) VRRm
                                3) VRMS
                                4) VF
                                IR is reverse current; lower is better, so the Newark part is better. You do realise the boiling point of water is 100°C, right? If your monitor ever got to 125 °C, you'd have more problems that the bridge failing.
                                PlainBill
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  ok....i think i get your meaning.
                                  thanks!
                                    Surface Mount Fuses Fundamentals Datasheet
                                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                    10-07-2024, 06:07 AM
                                  • nickgronk
                                    64PN5500 | BN44-00618A Main fuse keeps popping
                                    by nickgronk
                                    Power supply board BN44-00618A keeps blowing main fuse and nothing plugged in to it.
                                    I was gifted a 64PN5500AF, picture was amazing, but tv smelled like cigarettes and was dusty AF. I opened it up, blew all the dust out of it, removed PSB & main, and cleaned the metal underneath. Also blew all the dust off all other boards. Put the power supply back in, then mainboard. Soon as I turned it on there was a "pop".
                                    The main fuse (T12AH250V) blew
                                    I removed the power supply to be sure nothing underneath, all good. Soldered on a t12ah250v fuse and sure enough it popped...
                                    01-22-2022, 10:43 PM
                                  • edugimeno
                                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                    by edugimeno
                                    Hi There!
                                    I'm trying to help my friend who owns a restaurant be just bought.
                                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                    09-05-2024, 09:34 AM
                                  • dimis7
                                    LG 37LS5600 blows main fuse
                                    by dimis7
                                    Need some advice to troubleshoot this TV.
                                    PSU blow the main fuse F100, 3.15A.
                                    I replace the fuse with another 3A (but not ceramic) and blows it again after few seconds when i plugged in to the wall, with nothing connected to PSU, just the power cord.
                                    I checked with DMM for dead sorts but didn't found any.
                                    Checked bridge rectifier and seems ok.
                                    Also check main filter cap with transistor / cap / esr tester (the usual cheap transistor testers from ebay) and found ok.
                                    PSU p/n is EAX64405901 (1.6)...
                                    10-28-2022, 05:15 AM
                                  • cheeky2
                                    by cheeky2
                                    05-25-2024, 03:27 AM
