Samsung SyncMaster 2493HM - BN44-00195A - no power
  • doorzon
    • Jun 2015
    • 19
    • The Netherlands
    wondering if anyone has experience with the following problem.
    I have a Samsung SyncMaster 2493HM here with the infamous BN44-00195A power supply board.
    Been reading a lot of posts here on the forum about one or another issue with this power supply. In my case, the monitor is dead, the blue light does not turn on.
    When the PCB has power, I get 0.25V on the 5.3V, no voltage on 24V. The voltage across the main cap is around 310V, which indicates an issue with the PFC circuit according to other posts in this forum?
    All fuses are good, also the one on the logic board. But without 5.3V I suppose that does not even matter yet.
    There are some schematics around for this board, but non of them are of the actual board when I compare the power input stage. Does anyone have an accurate schematic of this board? Or is the schematic from here sufficiently the same for troubleshooting?
    https://www.badcaps.net/forum/attach...4&d=1344964111
    From first impression I cannot see any parts burned, no caps are bulged. The board actually looks pretty good optically (I've seen a lot worse, as well in other posts here).
    I still need to clean all the glue from the board, but it does not seem to be an issue, cannot see any burn marks even up close (see attached photos).
    Does not mean any of them could not be broken.
    Instead of shooting a cannon and replace all caps and some semiconductors and hope for the best, I'd like to understand and repair the parts that are broken.
    Any nudge in the right direction would be appreciated.
  • R_J
    • 9535
    Re: Samsung SyncMaster 2493HM - BN44-00195A - no power
    The first voltage you need to have is the standby 5 volts, this can be checked between ground and DB851 cathode. If you do not have this standby voltage, check RB801s, and RB808 (the res. between pin 1 and hot ground) if either is open, icb801s is likely bad and the small electrolytics around it need to be replaced as well.
    • doorzon
      • Jun 2015
      • 19
      • The Netherlands
      Hi R_J,
      thanks for the quick reply. After I did some measurements I decided to put the monitor back together partially. After this the power supply started to work again.
      So it looks like there is a loose contact somewhere on the power PCB. Standby voltage is there as well as the 24V. Monitor now works as before.
      If the problem comes back I'll pore some more time into this one. It's hard to find a fault if the damn thing is working ;-)
      The high voltage transformers on the CFL PCB do make distinct a lot more noise (I'd say around 100-150Hz) but so far this is not a deal breaker.
      Funny thing was, when I was measuring the voltage over a CFL power connection, even touching one pin of my multi-meter was sufficient to see some arching from this PCB island to my measuring pin. Did not expect that.
      Perhaps the CFLs draw too much power or the yellow caps on this power converter are going bad. Will have to see how long this thing will hold.
      Guess for now, this one is fixed!
      thanks,
      Doorzon
      • R_J
        • 9535
        CFL means something else to me.
        The transformers are switched at around 60khz~100khz If there is a poor connection it is likely on the components mounted to the heat sinks or the transformer pins, especially the ones with the rivets. If it happens again, re-solder those connections. You may want to re-solder the pins on the plugs like CN85, they don't look the best in the picture.
        • doorzon
          • Jun 2015
          • 19
          • The Netherlands
          Hi R_J,
          thanks, will do. appreciate the assistance.
          regards,
          doorzon
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mrtek
            Samsung UN43NU6950FXZA No power
            by mrtek
            Hi
            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
            Main fuse = OK
            Back light LED = OK. Power them with aux power source
            LED output = OK 156V
            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
            07-20-2025, 08:06 PM
          • hill01
            Samsung UE75MU7009TXZG Endless Power Cycle
            by hill01
            Hi everyone and thanks in advance for any help I might get here
            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
            Since a few days, the TV won't turn...
            11-17-2021, 02:52 PM
