Opening Dell E152FPc monitor
  • everell
    • Jan 2009
    • 1514
    I have been given a dead Dell E152FPc monitor. I have repaired many computer power supplies, but never tried repairing a LCD monitor. So my big question is......how do you get the back off without destroying things? I have removed the four screws holding the back stand. It is not obvious to me how this thing comes apart.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • starmaxpc
    • Oct 2009
    • 117
    Re: Opening Dell E152FPc monitor
    you will need to pry it open, probably with a flat screwdriver to start. it does snap on fairly tight so when you do get in between the panels it will eventually pop open. if you havent already the stand will have to come off also.
    • Radio Fox
      • Jan 2010
      • 281
      Sometimes, the hardest part of repairing a monitor, is actually getting the thing apart!
      I found that the best thing for getting between the 2 halves of the case, is a thin butter knife, the ones with a rounded end and no serrations.
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • everell
        • Jan 2009
        • 1514
        Got it open. Thanks guys.
        Now it is in a million pieces (not really a million....) and now I wonder if I will ever get it put back together again!
        • Borse2008
          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
          by Borse2008
          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
          • There’s
          07-15-2025, 04:55 AM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • DanPoka
          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
          by DanPoka
          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
          02-15-2025, 05:05 AM
          by momaka
          03-15-2023, 10:17 PM
        • Jesus Coder
          Issues Reviving Old Dell 2408WFPb Monitor
          by Jesus Coder
          I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
          06-25-2023, 02:33 PM
