VX922 with FSP035-1PI01 PSU
  • PlainBill
    • Feb 2009
    • 7034
    Re: VX922 with FSP035-1PI01 PSU
    Originally posted by Sparky
    lol, well I was given that nickname years ago when I first started playing with electricity (I was 10 at the time) and blew a few fuses, melted a few wires, sent sparks flying...
    The name stuck
    Hmm, sounds like something I tried at about that age. The name I got was a lot less pleasant. Good thing it didn't stick.
    PlainBill
    • masiril85
      • Mar 2010
      • 7
      I have this same board with a similiar problem. I replaced a few bad caps and my voltage steady out but the monitor would only flash on and off.
        master hoarder
        • May 2008
        • 12164
        • Bulgaria
        Might be inverter/backlight issue. Post some pictures of the PSU board if possible. Also, if the original caps were CapXon KF, replace them all, not just a few (except for the big 400v one). Panasonic FM and Chemicon KZE would be good replacements, but Nichicon PW and HE, Chemicon KY, and Panasonic FC might also work.
        • spiff59
          • Jan 2008
          • 13
          I have a VX710 flat panel with the exact same power supply.
          It will power on for approximately a second then go black. The power indicator stays on green and steady, and correctly switches to amber if the input signal is lost.
          While on, the screen looks fine, you can repeatedly display the screen for a (short) second by toggling the power, or holding menu button "2".
          So, I popped it apart expecting to find barfing caps, but none appear faulty. Although there are a couple of the notorious Capxon's.
          Closer inspection showed one (Q6) of the four transistors located on the bottom of the board, beneath the small output transformers for the backlight, is literally blown apart with a nice resulting scorch mark.
          Do you think this is a problem?
          Kidding!
          Ahem... to the real question, were I to track down a replacement for the part (it's marked DKQF), can anyone peer into their crystal ball and give me an idea if I should expect other components of the PS to also require replacement?
          Thank you.
          • retiredcaps
            • Apr 2010
            • 9271
            See
            https://www.badcaps.net/forum/showpo...95&postcount=6
            PlainBill wrote ...
            "Those transistors are Rohm 2SC4672. DK is Rohm's designation for that transistor, Q specifies the high gain range (P would be the low gain parts). I believe the last letter is a lot or date designation. Of course, the part may be available from other manufacturers."
            --- begin sig file ---
            --- end sig file ---
            • jetadm123
              • 2169
              #26
              Thank you.
              The DKQF is a 2SC4672 transistor made by Rolm and is available from digikey.com. Review the data sheet to make sure.
              Hah hah! Looks like retiredcaps beat me to it! Also, photos of your board would definitely help if you want additional info on parts replacement.
              • jetadm123
                • 2169
                #27
                I should also mention that you should probably replace these transistors in pairs, since the hfe of the new part will probably be different from the old one. Also, measure some the other components around the shorted transistor to make sure they're ok. Buy some spares because another failed component may have caused the transistor to short out.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Well said. buy plenty. At $.83 each, they're cheap enough.
                  I repaired one monitor by replacing the shorted transistors, resoldering the transformers, and replacing a cap that had come unsoldered. It worked perfectly the first time and survived all tests. I currently have another (same circuit, different brand) that has gone through two sets of transistors. Caps have been replaced, transformer passes ring test, transformer leads have been resoldered, etc.
                  PlainBill
                  • Redion
                    • Nov 2010
                    • 59
                    Hi everyone!
                    I got another problem with this power supply.
                    First it wont power on, Replaced the Caps>
                    Not flashing screen problem, replaced U3, W6, W7 >
                    Now its turning ON and shows the picture not problem, BUT PSU won't power down the back light when power button is pressed! So now the PSU is always ON!
                    I separated controller from the PSU and it still stays on, so it is not a logic board.
                    So far I tried replacing these bit still no luck: Q1, Q2, U1, U320, D9,
                    Any ideas?
                      That means the BL_ON control line is stuck high, this control line is fed from the main board, but since the main board is not connected and the backlights still stay on, it means the transistor or IC that receive the BL_ON/OFF line is stuck on and cannot be controlled by the main board any more.
                      We need to see good clear pictures of both sides of this power supply/inverter board so we can give you the test points o check.
                      • Redion
                        • Nov 2010
                        • 59
                        Please go here : https://www.badcaps.net/forum/showth...432#post278432
                          HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                          This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 03:44 PM
                          HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                          This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 03:36 PM
                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                          This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                          09-12-2024, 03:28 PM
                          HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i3-4130 Specification for Upgrade or Repair
