Viewsonic Q19WB
  • justintempler
    • Jan 2010
    • 5
    Viewsonic Q19WB
    My monitor finally died today after it started having problems staying powered up a little over a month ago. No big deal, I used the advance warning to replace it before it died. I do want to repair it though to keep as a backup.
    Inverter ILPI-025 REV:E 2007.01.15 79069140
    I have fixed numerous electronic items but never an inverter module.
    I have the unit disassemled.
    C815 1000mf 25v (bulging)
    C818 1000mf 10v
    These seem to be the two most important parts to replace as they are directly connected to the switching transistors D803 & D805
    I also plan on replacing:
    C820 47mf 25v
    C501 470mf 25v
    C817 470mf 25v
    I was open to suggestions from people with more experience as to what other parts you would replace, if any? It seems silly to me to just go ahead and replace every single cap on the board and totally ignore switching transistors and various diodes and what about the ceramic disc caps?
    Anybody know the part numbers/values of D803, D805, C813, C814 ?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Viewsonic Q19WB
    C818 1000mf 10v
    C820 47mf 25v
    C501 470mf 25v
    C817 470mf 25v
    See my response in the other forum.
    PlainBill
    • justintempler
      • Jan 2010
      • 5
      Re: Viewsonic Q19WB
      The Viewsonic Q19WB looks almost identical to the Acer AL1916W found here:
      https://www.badcaps.net/forum/showthread.php?t=7777
      The only difference I can tell is the Viewsonic has an additional audio circuit which is missing on the Acer AL1916W
      This is the attachement with the 5 caps I had planned on replacing:
      https://www.badcaps.net/forum/attach...chmentid=11474
      The audio section of the board has 5 caps which I can safely ignore replacing.
      so that leaves
      C807 47mf 25v
      C827 47mf 25v
      and the monster C804 100mf 450v
      That brings the total to 8 caps for replacement.
      D803 (SP10100c) D805 (SP1040c) are Schottky Barrier Rectifiers, I'll ignore replacing those unless someone thinks otherwise.
      • PincushionMan
        • 22
        Re: Viewsonic Q19WB
        so that leaves
        C807 47mf 25v
        C827 47mf 25v
        You probably shouldn't bother replacing the 100uF 450V. Senior members here (PCBONEZ et al) say that generally they aren't the ones that fail - even the CapXons are OK, because the conditions are less brutal. Plus it'll save about $6.
        • akmo512
          • 7
          Re: Viewsonic Q19WB
          The Problem was the power shut off after 1 sec
          The fix I only had to replace 1 CAP , I have Been replacing with similar farads MORE voltage to insure LIFE
          Look at the middle of the board closest to the inverter ...That was the cap for me
          Many problems result in power failure, I was lucky to spend 20$ on this monitor spent 30- min to an hour to fix great deal.
          • Mouse
            • Mar 2011
            Re: Viewsonic Q19WB
            I'm having a similar problem with a q19wb.
            Opened it up and found no evidence of any sort of internal damage, or bad caps.
            I read all the related threads and decided to change the same 5 caps anyways...
            Put it back together, no change.
            It turns on, receives signal albeit low light, grainy and flickery.
            After 2-3 seconds the display shuts down.
            I'm testing it as the second monitor on a dual display, so i can change the resolution while it's running.
            Upon the change, signal is received, display is dark, grainy and shakey, then off again.
            The dual monitor setup works fine with another monitor.
            • retiredcaps
              • Apr 2010
              • 9271
              Re: Viewsonic Q19WB
              If this is "2 seconds to black", then see (starting with post #13 and #14)
              https://www.badcaps.net/forum/showthread.php?t=10419
              Start with that and ask questions. Concentrate on
              a) bad caps
              b) bad secondary inverter transformer
              c) bad ccfl
              d) bad ccfl wiring
              --- begin sig file ---
              --- end sig file ---
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • StefanNg
                Viewsonic VX2718-PC-mhd SG2701B01-8
                by StefanNg
                Hi, Badcaps.
                I am troubleshooting a monitor
                Viewsonic VX2718-PC-mhd.
                Panel model SG2701BSG2701-8
                Symptoms is no image.
                This panel has 2 panel board connected by a U-ribbon.
                When I disconnected the ribbon, I get a perfect half screen image.
                I took some test point voltage, when ribbon disconnected.
                HVAA 8.38v
                FVDD12 1.21v
                FDD33 3.3v
                VIN 11.79v
                VAA 16.85v
                VGHF 30.16v
                VGL -8.02v
                CK1_I ~ CK8_I 1.403v
                CK1_L ~ CK8_L 8.26v
                When I connect both panel board
                HVAA, VGHF, and CKx_L...
                05-17-2025, 01:43 AM
              • Fagauthier
                Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                by Fagauthier
                I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                Model #EADP-64BF B
                The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                07-08-2023, 08:02 PM
              • Returning Buick
                Viewsonic G810 vertical deflection problem
                by Returning Buick
                I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                04-01-2025, 07:57 PM
              • RetroComputingGrotto
                Viewsonic VA2010wb (High Pitch Squeal At Power On)
                by RetroComputingGrotto
                I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                What component(s)...
                02-03-2025, 06:00 AM
