Emprex LM-2203 Very dim
  • kickercivic1
    I have 22" Emprex LM-2203 and when first turned on it comes on nice and bright and after couple seconds it gets very dim, Whats the reason for this?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Emprex LM-2203 Very dim
    Try it in a darkened room. If there is NO light coming from the screen you have what is often called the 'two seconds to black' problem. It could be a problem with the inverter, the CCFLs, or even the wiring to the CCFLs.
    If there is still some light coming from teh screen, I wouldn't even hazard a guess.
    PlainBill
    • kickercivic1
      i think its the CCFL because before it turns off i hear sparks sound from the top left of the LCD.
      • PlainBill
        • Feb 2009
        • 7034
        Either CCFL or wiring. It's time to start disassembling it until you find what's arcing. If you need help, post pictures of the problem area.
        PlainBill
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • twonk9098
          Lenovo Legion 5 high fan spin turns off after 34 seconds
          by twonk9098
          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
          I have tried a few new bios but exactly...
          07-14-2024, 11:19 AM
        • liquidzorch
          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
          by liquidzorch
          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
          10-18-2024, 05:19 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
        • PowellSkier
          Harman/Kardon AVR 645 returning to stand-by after a few seconds.
          by PowellSkier
          A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
          06-17-2024, 11:43 AM
