I have 22" Emprex LM-2203 and when first turned on it comes on nice and bright and after couple seconds it gets very dim, Whats the reason for this?
Emprex LM-2203 Very dim
Tags: None
Re: Emprex LM-2203 Very dim
Originally posted by kickercivic1I have 22" Emprex LM-2203 and when first turned on it comes on nice and bright and after couple seconds it gets very dim, Whats the reason for this?
If there is still some light coming from teh screen, I wouldn't even hazard a guess.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
i think its the CCFL because before it turns off i hear sparks sound from the top left of the LCD.Comment
Originally posted by kickercivic1i think its the CCFL because before it turns off i hear sparks sound from the top left of the LCD.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
by twonk9098Hi all,
I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
I have tried a few new bios but exactly... -
by liquidzorchHello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by PowellSkierA Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
06-17-2024, 11:43 AM -
by SchwoinHey everyone,
the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
you can see them on the top half of the photo.
At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
... - Loading...
