Gateway 24" LCD Model LP2407
    Re: Gateway 24" LCD Model LP2407
    Here is the order for the Logic Board capacitors, the only one I was a bit iffy on was the last one but I think I got it right as well...
      The logic board caps are here
      Should I start swapping those mofos? Though I could wait for the better iron to see how that one handles the job... What do those readings with the logic board plugged in tell you?
        List looks good to me. For the last one, you could have gone with a 25V or even a 50V cap so that you can find Panasonic FC/FR/FM or other equivalent low ESR caps. But what you got will still probably work. The LCD logic board typically rarely requires low ESR caps.
        _ I will order some IPA, or can I just pick it up at CVS/Wallgreens, etc?
        Yes, you can get IPA from CVS or any other pharmacy store. Just try to get one that has 90% or higher alcohol content. I've used regular rubbing alcohol before as well (I think that is somewhere in the 70% mark) and it worked. But the 90% and higher dries faster and dissolves flux better.
        _ Which brings me to... Can I steal some of the wife's "Regular Polish Remover" from CVS to clean off the brown glue residue from that other project you are helping me with (Klipsch speaker)?
        Yes.
        I'm not sure how well it will work, but I think it should. Nail polish remover usually has Acetone in it, as well as a few other organic solvents similar to Acetone. So give it a try.
        _ I am not sure what kind of flux I got. It does say a bunch of stuff in Mandarin (I think), and the brand is Longyuan.
        It's very likely regular rosin flux. Just in solid form. Good enough for regular everyday soldering.
        Ok, I completely removed the LCD Inverter and the little USB board, I plugged in the logic board to the power board (flipped and on the back of my mouse pad) then I plugged in the power board and took all the same measurements as before:
        LCD INVERTER CN ON THE POWER BOARD (left to right towards LCD Inverter):
        1. 0V
        2. 3.28V
        3. 0V
        4. 5.18V
        5. 0V
        6. 0V
        7. 25.9V
        8. 25.9V
        LOGIC BOARD CN ON THE POWER BOARD (starting from the red cable)
        1. 5.18V
        2. 5.18V
        3. 5.18V
        4. 5.18V (also red)
        5. 0V
        6. 0V
        7. 0V
        8. 0V
        9. 3.28V
        10. 0V
        See that 3.28V? That's either the backlight dim/brightness signal or the inverter ON/OFF signal from the LCD logic board. Thus, it looks like LCD logic board may be fine as well (by that, I mean not dead from when you thought you had shorted the power supply or when the sparks came off from that connector on the inverter board).
        As a next step, I would say try to fix your solder joints on the inverter board and measure all of the voltages again. If all is good, these voltages should remain more or less the same to what they are now.
        Wait for the (hopefully) better iron. The 30 Watt iron will make you want to cry if you attempt to change caps on the LCD logic board.
        Also, do the test I suggested above first. That way, we know if the inverter is shorting the power supply or not.
          Ok, so I thought I tested the caps on the inverter board properly using the multimeter, I remember getting a beep...
          I just tested them again and I only seem to get a beep on the leads that look the worst (the ones where I had to use a ton of solder). These are the negative leads.
          I only get a short beep sometimes, usually when I first touch it, but it is very short and I have a very hard time reproducing it.
          I thought that the problem might be that the positive sides of the caps didn't have any solder at all on the top side, only on the bottom... so I quickly added some solder to the top side, but after re-testing I still get the same... no beep between either cap when I try continuity between their positive leads and the power connector.
          Maybe I did kill the caps when that sucker sparked like there was no tomorrow..? How can I test the cap itself? I looked that up and found I needed to set the multi to Ohms (2000k), and hook it up to both leads... I got about a 600-and-something reading and it quickly went down until it reached 1.
          I tested both several times and I get what seems to be kind of random values that almost always go down to 1 in a matter of a second or two. Sometimes it starts around 400, sometimes 1200, I even saw -120 or so. Almost always it drops down to 1 within a second or two, but sometimes it stops at 2.
          I tried a new and un-used 1000uF 25V cap and I get a very low value that slowly climbs higher and higher over time.
          BTW, the caps in question are still on the board.
            That's typical when "testing" caps with your multimeter. Basically, it is the capacitor charging up from the multimeter. Because the capacitor is initially discharged, it will draw more current from the multimeter, and the multimeter will see a low resistance and/or beep at you... but this only happens for a short moment or two, because the capacitor quickly charges up and stops drawing current. Then the multimeter sees that as a high resistance.
            First test for continuity between the negative lead of each capacitor and the pins on the power connector. At least a few pins should show a low resistance and/or multimeter beeping at you for several seconds (a quick beep does not mean good continuity). If YES, then the negative lead on the capacitor is connected. Next, repeat the same procedure, but on the positive lead of each cap. Again, your multimeter should beep or show a low resistance for more than a few seconds to some of the pins on the power connector. But note: you should NOT get continuity / low resistance / beeping between the capacitor's positive and negative leads - at least not when you keep the multimeter probes connected for several seconds. (Again, a short beep is OK - usually means a capacitor somewhere charging. But a loooong beep typically indicates good continuity.)
            No.
            When you say "went down to 1", is that the leftmost digit "1" on the multimeter screen or is it something like "1.0" or "1.00" or similar?
            The reason I ask is because I want to make sure you are not confused about reading your multimeter.
            For manual-ranging multimeters, a digit "1" on the leftmost side of the screen typically means out of range value - i.e. the value you are trying to measure (whether it is resistance, or current, or voltage) is too high for the scale you have selected and you need to go to the next higher scale.
            On the other hand, a number, such as "1.0" or "1.00" or "10.0" or "100" or "1000" is different from the "1" digit described above - these numbers represent an actual reading.
            As for auto-ranging multimeters, you typically get a "OL" on the screen if the value you are trying to measure is too high for the multimeter.
              I get a continuous beep between the negative on both caps and 3 of the power connectors.
              I get a SUPER short beep, not even half a second, between the positives on both caps and the same 3 power connectors.
              [QUOTE=momaka;668471]But note: you should NOT get continuity / low resistance / beeping between the capacitor's positive and negative leads - at least not when you keep the multimeter probes connected for several seconds. (Again, a short beep is OK - usually means a capacitor somewhere charging. But a loooong beep typically indicates good continuity.)[quote]
              I get no sound at all when connecting the positive and negative connectors. Same for both of the capacitors.
              No.
              Good stuff! I was dreading having to wait for a shipment of 2 caps hehehe
              Yup. Thank you for helping me out. To be safe I just checked them again. They both started somewhere around 300 or 200, then dropped to "001". Then I used a screw driver to discharge them and tested them again, they started with a small negative value them went up gradually and dropped again to 1.
              So, does it look like we are on to swapping the caps on the logic board? It seems everything else might be ok, right?
                Good. So the negative leads are connected well then..
                Good.
                That means the positive leads on the cap are also making contact. If you had a long beep / good continuity to the same 3 pins as the negative leads, then I would have been worried, since that would indicate a short-circuit between the 24V rail and ground. But since that is not the case, were are okay here.
                Okay, sorry, but you got me confused again. First you say dropped down to "001", then to "1". Again, be specific. If it's a "1" on the left side of your multimeter screen with no other digits behind it, then that is an "out of range" indicator. When you get that, just say "I get out of range reading". That way, we (err. I? ) don't confused about what you are seeing.
                Yes sir.
                Seems so right now.
                That said, were you able to (temporarily) fix the cable between the power and inverter boards?
                  Hahaha, sorry, yes, both times I meant "001"
                  Yes sir.
                  Gosh, should I be worried about these little soldering points?
                  How does it work when it comes to "safe areas" for people that use 3 lbs of solder like me?
                  Seems so right now.
                  No, let's order it... I am concerned about blowing the whole thing up again
                    Ugh... I am getting a solid tone from the multi when testing for continuity between these two points. I used the vacum pen a million times and I still can't seem to get rid of whatever is connecting the two points, with or without the cap. I tested the cap and it seems to be ok, but the beep is there even when I test like this (photos):
                      Pheeew, I think I got it, please disregard the last post, working on the rest now.
                        %#$@!! Now I have the same issue with another one of those small tight cap holes... is there a trick that helps to clean up the PCB so that I stop getting connectivity between the holes even without a cap installed?
                          BTW, 001 Ohms, or 001K Ohms?
                          I doubt that the cap shorted out.
                            I was using 2000k to test them
                            Budm, do you have any tricks to cleaning up the PCB? I am getting connectivity between two of those points even without any solder (that I can see) and without a cap installed...
                              "I was using 2000k to test them" Then it is not shorted then, you need to use 200 Ohms scale.
                                Nevermind, I think they are all fine, some of them just beep for about a second or so before shutting up
                                Cool, makes sense.
                                Question, the little 10uF 16V however gives me an infinity reading (1 on the left). Is that normal.
                                Assuming it is, I am ready to rest but I would much rather order the cable than short the whole thing out again. Where can I get this:
                                  It looks like JST connector:
                                  http://www.ebay.com/sch/i.html?_from...n+jst&_sacat=0
                                    Awesome. Thanks Budm!
                                    Does this look like the right one? Not like I am going to see it anyway
                                    http://www.ebay.com/itm/5-Pcs-2-54mm...AAAOSw7hRWPFUv
                                      Like I said, that's other caps in the circuit charging up, so don't worry about it if beeps quickly and stops.
                                      That's why I usually suggest to check with the 200 Ohm scale, and not anything else. Continuity is a very general setting - typically used for simple stuff, like seeing if a long wire has breaks in it. Continuity is NOT good for determining if stuff is shorted or not. Most multimeters will show continuity and beep only if resistance is less that 25-100 Ohms... which again, is NOT a good indicator for short circuit.
                                      Yes.
                                      In theory, capacitors have infinite resistance. But some caps can become (electrically) leaky, so you may actually see a high resistance across their leads. This is all out-of-circuit measurements, of course. In circuit, it can be a completely different story, depending on what is connected to that capacitor.
                                      Looks okay to me. But it is an 8-pin connector, whereas yours looks like a 9-pin. Or am I mistaken here?
                                      Just use less solder and more flux to re-do the joint until it looks right.
                                      I'm wondering, though... are you using your new adjustable iron or the "old" 30 Watt one?
                                        The one that broke is the one going to the LCD Inverter, which has 8 cables.
                                        I haven't received the new adjustable one yet, and I was hoping to fix this quickly so I got impatient and went for it. Things went a lot easier than the first time, so I think a lot of it was just inexperience. I think the only reason why things took a while this second time around was just not knowing enough to interpret the readings I was getting.
                                        I "fixed" the cable with a lot of silicone applied in batches, little by little adding all the cables and making sure they weren't going anywhere. I plugged it in and applied a little more silicone to the cable since this will be is resting position. Once it dried up a bit I tested for continuity and I got a solid beep on each cable, between the connector on the power supply and the male connector that is soldered into the LCD inverter.
                                        Everything checked out so I went for it and tested with the component out of the TV receiver...
                                        ...the menu lights up, but the screen stays full black all the time, through power up and no matter what I do.
                                        What gives now?
                                        We've replaced all caps on Logic board, all caps (but the big one) on the power control, and both caps on the LCD inverter. The cable that cracked looks to be OK.
                                        Could it need to be flashed? Maybe the software got wiped?
                                        Could it be that all along it was the backlight that died?
                                          If I power up the monitor without a signal, allowing it to boot up and go to sleep as it normally would without any signal being fed, THEN I plug the TV signal in... based on the menu buttons lighting up I can confirm that it does in fact detect the signal.
                                          This points away from the ROM needing to be flashed with the software again. Instead it points towards the backlight, or something else having to do with the LCD inverter, but not the logic board...
