Re: Gateway 24" LCD Model LP2407
Hi USchabon, welcome to the BCN forums!
While a multimeter is a great tool to have for troubleshooting electrical/electronics problems (if not the best), you can't really use it to test for bad capacitors. To do that, you need an ESR + capacitance meter.
Most "dedicated" ESR/cap meters like the ESR-micro and Anatek-Blue are somewhat expensive and not really worth getting just to fix a single LCD monitor. Cheaper alternatives do exist, though, such as the open-source ATMEGA-based ESR meter like this:
http://www.ebay.com/itm/128-64-ESR-M...sAAOSwpdpVX9Ku
But you don't really need an ESR meter to troubleshoot your monitor. Just change all of the capacitors (sans the big high-voltage one, unless it has corrosion on the leads) if they are from a bad or cheapo brand. Or to put this into a different perspective, any capacitor that is not made by:
Rubycon
Nichicon
Panasonic (i.e. Matsushita, which means you will see a small [M] logo)
United Chemicon (small squished interstate-like logo)
Sanyo (beware of many fakes online)
Fujitsu
....... should be considered for replacement.
I see lots of Su'scon and a few Teapo on your power board - all of those need to go (except for the big cap). Looks like the failed Su'scon have "SG" written on them. That would be their series name. If you look for "Su'scon SG" online, you should hopefully get to this datasheet:
This should tell you the ESR/impedance and ripple current (RC) specifications for the capacitors you have (these are the other two important parameters besides the capacitance and voltage ratings).
In general, you pick capacitors in the following manner:
Same or next higher voltage rating
Same or next higher capacitance rating
Same or higher ripple current
Same or lower ESR/impedance
For monitor power supplies, it is *usually* not critical if you pick capacitors that don't quite match the ripple current and ESR/impedance ratings very well. It's just that you new caps may not last very long if they are not rated properly. But again, if you stick to a high-quality Japanese brand, your new caps will still likely outlast these cheaper ones that failed.
In general, for this type of work you will need a 40-50 Watt iron. 60 Watt will be okay too, but the irons tend to run very hot and quickly burn through the tips. 30-35 Watt irons are also okay, but only after you've done a bit of soldering before, because the lack of "heat capacity" in those irons may cause you to struggle with some solder joints.
That said, these two on eBay seem like pretty good deals for the money:
http://www.ebay.com/itm/New-9in1-110...kAAOSwFqJWnx8J
http://www.ebay.com/itm/14in1-Electr...IAAOSw5ZBWOW-z
Just note that I haven't used either of these irons before, so I can't comment on their quality. Most likely they will work okay. Just don't expect the tips to last a long time. And their overall quality is probably quite low.
Or, if you have a Home Depot near you, these could also work:
http://www.homedepot.com/p/Hakko-40-...-1-P/204215977
http://www.homedepot.com/p/Hakko-60-...ED-P/204215957
However, you will need to buy solder separately with these irons (whereas the eBay irons included it).
Which brings me to my next point: solder. For a beginner, you might find it easier to work with standard 60/40 leaded solder. Lead-free has a higher melting temperature, so it may be a little harder to solder with it. In any case, I also recommend you get some rosin flux. Either liquid or solid will do (the eBay kits also include flux, but it is in a solid form, so you will need rubbing alcohol/IPA to dissolve it). Just avoid any flux with "RA" in the name (i.e. Rosin Activated) or "Plumber's" flux, as those are aggressive fluxes that can eat through the circuit board traces.
As for how to desolder your caps... I use this method:
https://www.badcaps.net/forum/showpo...7&postcount=23
Then I clean the holes in the board by heating them and pushing through on the other side with a sewing needle or cork board tac/pin.
Then solder the new caps in place.
As for the replacement caps you picked, I will address that shortly as I check what you ordered.
Good to hear that!
Just be careful, because you might catch the badcap repair "bug". And then there is no stopping doing this stuff. I'm talking from personal experience here.
Originally posted by USchabon
View Post
Rubycon
Nichicon
Fujitsu
View Post
View Post
