Samsung LED SA450 22"
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Hi i need bios dump for this model of monitor
    https://www.samsung.com/us/support/o...r-sa450-series
    when i plug vga no images
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Re: Samsung LED SA450 22"
    my orginal bios
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      Any help
      • digitalpc
        • Jun 2016
        • 305
        • .DLL
        I forgot,
        I can't reset my monitor
        lock menu
        i try pressing menu for 10sec but not working
        • datodati962@gmail.com
          • May 2020
          • 48
          • alb
          Hi body,if you solve your problem can you send me a good bin,i have the same issue
          • lotas
            • Jan 2016
            • 4524
            • Russia
            Samsung LS22A450BWT/CL (Main Board): BN41-01654B dump
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • jeewantha
              Samsung NT-R580 Bios Dump Required
              by jeewantha
              Hi Guys,
              I need a bios dump for the following laptop.
              Samsung NP-R580
              Motherboard : BREMEN-M REV:1.0 (091112)-5
              Serial Number : BA68-05578A 20
              Thank you​...
              05-20-2025, 05:03 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
            • DynaxSC
              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
              by DynaxSC
              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
              11-06-2022, 05:22 PM
