Samsung LED SA450 22"
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Hi i need bios dump for this model of monitor
    https://www.samsung.com/us/support/o...r-sa450-series
    when i plug vga no images
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Re: Samsung LED SA450 22"
    my orginal bios
    • digitalpc
      • Jun 2016
      • 305
      • .DLL
      Any help
      • digitalpc
        • Jun 2016
        • 305
        • .DLL
        I forgot,
        I can't reset my monitor
        lock menu
        i try pressing menu for 10sec but not working
        • datodati962@gmail.com
          • May 2020
          • 48
          • alb
          Hi body,if you solve your problem can you send me a good bin,i have the same issue
          • lotas
            • Jan 2016
            • 4759
            • Russia
            Samsung LS22A450BWT/CL (Main Board): BN41-01654B dump
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • Kjell
              Samsung Series 9 - BIOS issue
              by Kjell
              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
              08-01-2025, 09:15 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers 😀,
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              💀 Problem:😅
              08-07-2025, 04:54 AM
