Chimei CMV221D black screen ?
+ More Options
Posts
  • jh20
    • Jul 2012
    • 27
    • australia
    Re: Chimei CMV221D black screen ?
    do we have a solution to the op's problem? i have the same monitor with the exact same psu board and exactly the same problem as well.
    i have replaced all the capacitors on the board and it's still not fixed. the strangest thing is if you switch it off then on, it comes back for a few more seconds before going dark again. so it is definately not a hard failure issue.
    have done what plainbill suggested and got exactly the same result as the op's. no image at all when off, and the voltage at the fuse are 19.1 when on and 21.6 when off. so what does that mean? login board issue?
    i have also checked the output voltages from the psu. the 5v is 4.95v and 13.8v is 13.81v. the 5v is a touch low but don't think that's an issue? the voltages stayed the same whether the screen is on or off.
    any more suggestions or tests to do before i binned it?
    • jh20
      • Jul 2012
      • 27
      • australia
      Originally posted by Bobdee
      That looks the same Power suppy/Inverter as this Thread
      https://www.badcaps.net/forum/showthread.php?t=8265
      Might help with Common faults
      forgot to read this thread first before posting
      so looks like it's the tubes problem. not to worry, i'll just bin it. it's too old and the colour quality is bad anyway.......
      thanks for reading.
      • jh20
        • Jul 2012
        • 27
        • australia
        Originally posted by PCBONEZ
        Common failure mode.
        I've done that one more with laptops in which it's usually a bad inverter or tubes.
        just a follow up as i decided to get to the bottom of this.
        pcbonez was right! i pulled the screen apart and the top ccfl has a broken tube (pair of 2). replaced the pair with one from a lg 22" monitor that has a broken lcd and the problem seems to be fixed. monitor has been on for the last 1 hr and it's still going
        unless it falls over later, otherwise consider this as fixed
        • Amraks
          • Nov 2011
          • 725
          I picked one of these up for 10 dollars today and its not turning on.
          Can't wait to investigate more. Things have been quite lately in this field.
          apart from stereo I am fixing.
          • HTR-Informatique
            Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
            by HTR-Informatique
            YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
            I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
            On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
            I also changed the screen because the PC fell and the screen was broken.
            I changed the battery with a new and original battery.
            I also had corrosion/oxidation on the...
            02-09-2025, 06:51 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • VcemPzd
            Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
            by VcemPzd
            Hello everyone !
            My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
            04-28-2025, 10:14 AM
          • DaniK
            Acer Aspire E5-574-52RH - black screen
            by DaniK
            I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
            Laptop came in for a SSD upgrade, took everything apart to install the SSD.
            Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
            Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
            The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
            Symptoms are:
            - random black screen after displaying Acer logo...
            02-21-2024, 06:27 AM
          • turmix
            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
            by turmix
            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
            During another reassembly, I made a mistake, and...
            01-29-2024, 03:48 AM
