cy199 i-inc showing blue and yellow led only when connected
  • PlainBill
    replied
    Re: cy199 i-inc showing blue and yellow led only when connected
    Originally posted by stj
    most gear with an eeprom will set it to default values if it's blank.
    so take it out and erase it.
    no eraser? by an new blank one - they cost less than a €.
    And even that my not be necessary. Google reset monitor and look for instructions for your monitor.
    PlainBill
    replied
  • andrei dragosh
    replied
    Hello
    This is for people that might read this in the future.I repair
    LCD Monitors.The INC 199 monitor does lose its hex file as time
    goes on creating the blue to yellow flashing light.It can be repaired.
    It needs the file and a programmer.I can do this if people want.
    rob123m@yahoo.ca
    hello , i'm new on this forums and i have the same eeprom problem,..can you help me whith the hex?...you can send him on email
    ionutz_2701@uahoo.com
    thx
  • rob123m
    replied
    Hello
    rob123m@yahoo.ca
  • Surej
    replied
    I used another eeprom from one small 7 inch screen and it worked. so i think the eeprom dont have any valid data to start the screen or else it wont work . have checked all menu function and it's working properly. the setting can also be saved.
    Thanks for all the help...
    Regards
    Surej
  • PlainBill
    replied
    Originally posted by dondrusco
    I go through this forum, and I found something about similar issue. Solution - reset unit.
    https://www.badcaps.net/forum/showpo...11&postcount=5
    Excellent!! It might take some experimentation to find the proper buttons, but that looks like a procedure to reset the EEPROM to default conditions and clear the corruption.
    PlainBill
  • dondrusco
    replied
  • hardwareguy
    replied
    Make sure you replaced Low ESR caps with Low ESR replacemnts.
  • Surej
    replied
    Thanks I'll try and let you know..
    Surej
  • PlainBill
    replied
    Sounds like you may be SOL unless you can find the service manual.
    Contrary to what one user said on Fixya, the eeprom is not read-only. It stores the brightness and tint settings, as well as a number of other settings. I'm sure the problem is that it has been corrupted, and the manufacturer failed to provide a 'reset to defaults' function in the firmware. There might be a good reason for that.
    I do have one suggestion. While reading the service manual for another monitor I noted that if the Auto and Select keys are held down while the power button is pressed the monitor enters factory setup mode.
    There is very little that is unique to a particular monitor line. Many brands are distinguished only by the color of the plastic and shape of the base. I'd suggest trying holding down all possible combinations of buttons while turning it on. If the monitor has only 4 buttons plus the power button, there are only six possible combinations of two buttons, four of three buttons, and one of all four.
    PlainBill
  • Surej
    replied
    I googled this and some prople have fixed this issue by reprogramming the eeprom...but i still could not find the eeprom file to flash it..seem to be a software issue..
    http://www.fixya.com/support/t636635..._will_not_turn
    post no 7
    Surej
  • PlainBill
    replied
    Originally posted by Surej
    I got a cy199 i-inc 19 " screen that when connected shows only blinking blue and yellow led.
    The pictures are attached.. I have changed all the capacitors but still no luck..
    any idea how to fix this..?
    Surej
    You'll have to be more explicit. Are you saying that when you press the power button the LED goes to blue, then changes to yellow, but the screen stays blank? In that case, I would look for problems in the backlight circuit.
    Or are you saying that you have blinking blue and yellow LEDs and a blank screen? In that case, I would suspect a problem with the logic card.
    What brand were the original caps. What brand and series did you replace them with?
    PlainBill
  • cy199 i-inc showing blue and yellow led only when connected
    Surej
  • sli4
    Original NES power issues
    by sli4
    I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
    I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
    Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
    On the big blue connector I get...
    11-28-2024, 12:52 PM
    Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
    This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-07-2024, 05:50 AM
    Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    09-07-2024, 05:00 AM
    Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
