cy199 i-inc showing blue and yellow led only when connected
  • pellelu
    • Aug 2011
    Re: cy199 i-inc showing blue and yellow led only when connected
    Hi, is anybody can provide an exact part number for that specific monitor? (I-INC CY199). It looks like I found the fix for my problem with this EEPROM issue. I think I can do the job but I feel unsafe concerning the right part to buy...
    Thanks a lot in advance for your advice!
    • 1supertech
      • Apr 2012
      • 384
      Originally posted by Surej
      I got a cy199 i-inc 19 " screen that when connected shows only blinking blue and yellow led.
      The pictures are attached.. I have changed all the capacitors but still no luck..
      any idea how to fix this..?
      Surej
      Hello everyone I have the same problem and the conclusion to this is an eeprom Digikey part# 24LC16B-I/SN-ND
      according to the image of the mainboard The image has two such chips with eight legs which one is the eeprom or are two. eeproms
      Thank you
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        On your machine do the two chips have any writing on them?
        Did you try the button resets mentioned earlier?
        • sabre504
          • May 2010
          • 449
          Hi just done 2 of these have circled in red the chip that needs replacing.
          Once done turn on power and it may flash blue and yellow a few times before it sets up if not turn off and on again .
          Of the 2 i did one fired up straight away the other needed turning off and on again .
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Anyone know if these eeproms can be reset/wiped without having to remove?
            • sabre504
              • May 2010
              • 449
              #26
              Originally posted by rob123m
              Hello
              This is for people that might read this in the future.I repair
              LCD Monitors.The INC 199 monitor does lose its hex file as time
              goes on creating the blue to yellow flashing light.It can be repaired.
              It needs the file and a programmer.I can do this if people want.
              rob123m@yahoo.ca
              Earlier post
              But they are not difficult to change .
              Mind you i did use chipquik as i have some left over from another job .
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #27
                Yes I saw that but as you are replacing with a blank unwritten chip it obviously doesnt need programming.
                I understand some atmel eeprom chips can be reset by shorting 2 pins SDA and SCL and wondered if it would work on this as well.
                If it did work it would be a lot easier than removal
                • sabre504
                  • May 2010
                  • 449
                  #28
                  Well i looked all over net and couldnt find a combination of buttons for a reset,tho someone else may have ?
                  Also looked for a way to short but again no joy so went the replace route .
                  But i suppose it would be worth a try and if it did'nt work then can still be replaced .
                  • 1supertech
                    • Apr 2012
                    • 384
                    Well according to the image that Sabre54 put up it's the one on the right in red, their is another that looks like it on the left
                    yup I tried the button reset no luck
                    • sabre504
                      • May 2010
                      • 449
                      #30
                      Only the one i circled needs changing .
                      Cant remember numbers on the other one but not the same anyway
                      • michal_w
                        • Jun 2012
                        • Poland
                        #31
                        Hello all,
                        can be the eeprom "EE24C16P (24C16-10PI-2,7)" use instead of the factory-soldered "24LC16BI SN0646" ?
                        Thanks in advance,
                        Michal W.
                        • 1supertech
                          • Apr 2012
                          • 384
                          Received my eeprom for my cy199 I-inc after tree tries I finally got it in right
                          and working. with out hot air it's a PITA.
                          • hmagga
                            • Aug 2013
                            • italy
                            #33
                            same problem led blink yellow and blue ,BLACk screen i dissolder the eeprom 24c16 ,the led blue FIXed But THE screen is black,there is a way to factory default this f**g eep
                            • sli4
                              Original NES power issues
                              by sli4
                              I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
                              I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
                              Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
                              On the big blue connector I get...
                              11-28-2024, 12:52 PM
                              Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                              This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-07-2024, 05:50 AM
                              Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                              09-07-2024, 05:00 AM
                              Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                              Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
