Bad CCfL Tubes
  • xtraelectronics
    • Apr 2009
    • 49
    Bad CCfL Tubes
    I just recently repaired an ACER1916W. The Caps and circuit all checked out ok. The monitor would be on for the typical 5 seconds, then black. I determined the CCFLs to be bad. Then I discovered the return wire on the top tube was loose. Poor soldering, so I resoldered the lead wire, and shrink tube, just like original. This corrected the problem. -Until everthing was put back together. Took it all apart again. Bottom tube was acting up. Could smell ozone when it was running. So I stripped off all the shrink tube, and resoldered all connections, along with new shrink tube. Put it all back together, and success! The inverter was shutting down due to leakage current @ the tubes' ends. This was very tricky to find, and might have made the monitor appear "unrepairable". It was very frustrating, but worth it.
    I have found several monitors with CCFL issues that were repairable. If the monitor appears to run fine with "test tubes" (I keep a set of tubes on the bench to check the inverters), then perhaps the tubes are "leaking". Signs are a funny smell (ozone), and/or a crackling/buzzing sound coming from the tubes. I am suspicious of the failures of the Benq's being caused by this. Further testing on the bench will yeild more details. (I have several Benq's here to look at).
    Just my my 50 cents.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Bad CCfL Tubes
    yes this happens.
    just fixed a free 27" audiovox lcd tv with a bad joint on a ccfl.would run fine for a while and drop the backlight.tapping it just right would trigger it too.found it by poking around with a plastic tool.poke ccfl return wire and pssst shutdown.
    • xtraelectronics
      • Apr 2009
      • 49
      Re: Bad CCfL Tubes
      Update:
      Tackled one of the Benq's today (FP731). Initially, it would power up, display for a few seconds, (very bad pinkish/red tint to it) then shut down, green light still on. Upon disassembly, found 6 bulged caps on the inverter/ PSU. Replaced them, and resoldered the inverter section. Monitor now runs without shutdown. Still had pink/red tint. CCFL tubes were shot.
      Had another dead monitor, (T705), so I exchanged the entire screen assembly, it now works perfectly! I will likely repair the PSU from the T705 for use later. I have several of these PSU/ inverters with spare parts, such as transformers, etc. if anyone is stuck, contact me. (Most of the 5707 transistors are gone). -Better to use new ones anyway.
      Dan
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • mikey5791
        Help on Samsung Syncmaster T220 dead ccfl lamp
        by mikey5791
        This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
        Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
        10-18-2020, 03:17 AM
      • DCJack
        B&K 707 tube tester. I need help.
        by DCJack
        Hi everyone!
        I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
        Initially I noticed that I was not getting the red on-light to turn on, but it...
        03-05-2024, 05:05 PM
      • Topcat
        Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
        by Topcat
        This was rescued from a recycle gaylord from a hospital along with some other things....
        I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
        Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
        08-02-2023, 10:07 PM
      • edugimeno
        "First Experience" with a CFL BL Samsung TV
        by edugimeno
        Hi There!
        I just wanted to share experiences trying to fix for the first time a CFL backlight Tv. It is samsung LE32A336J1N
        The issue it was showing was: As soon as I turned it on, the BL would turn on/off for 2-4 times and them off definitely
        I suspected the BL voltage generator or the LED strips, at least until I opened it up, cause I had never seen these TV's
        When I opened it I found a very robust TV with a complex chassis formed by mutiple arms tied together with screws. There was a large PS board with several transformers for backlight,...
        05-28-2023, 03:41 PM
