Board compatibility
  • cosmarchy
    • Jan 2020
    Board compatibility
    I have a Dell 2007WFP which does not work. I think it is the USB board but cannot be sure so I've been looking around to see if a replacement is cost effective or whether to scrap the whole thing.
    The board is a 4H.L2J08.A03 which I don't seem to be able to find anywhere. I can get hold of a 4H.L2J08.A04 though. Is the Axx number at the end just a revision number or is this a completely different board? Would it be compatible?
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • rustinjust
    Technika lcd 32 - 207, question about board compatibility
    by rustinjust
    My main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
    Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
    Link to part here https://www.ebay.co.uk/itm/222990805243
    This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue...
    10-06-2023, 08:53 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • edugimeno
    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
    by edugimeno
    Hi!!
    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
    At a certain point, moving stuff around, I put all wires back in place and...
    03-24-2024, 02:31 PM
