Dell 23" monitor model ST2310f inverter fault
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Hi guys,
    I got in this set and i need some advice. There is an IC on a small upright board that solders into the power supply that drives the ballast transformer. The chip is marked AO3436 and has the shape of a rectangular 8 pin SMD I C. The chip is two mosfet transistors in one ic package. I get no info on this chip and neither a schematic online. I am not closeby to take photos because at that time i gave up trying to fix it. Does anybody in the forum know what i am talking about and can advise me on how to proceed. Its only a replacement chip that i need or maybe configure two n-channel mosfets to do the work.
    Regards
    Angelos
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • ed1i
    Dell Inspion 7610 bios chip
    by ed1i
    Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
    01-16-2025, 02:14 PM
  • donnietr
    Need help id'ing chip on a Dell g15 5515
    by donnietr
    Hello all,
    I have this dell g15 Ryzen Edition 5515. Board GDL56 LA-K453p. It had liquid damage when i bought it. Cleaned it up really well and then used thermal camera to see what got hot.
    Found the power pdw1 and pdw2 under the graphics card were getting hot. Pdw2 was hottest, i had a similiar chip on another board so i put it on this board.
    The other chip is now hot as well, which it was to begin with.
    Thats the problem as i dont know what to call it, like is it a mosfat? or what?
    I will attach a picture of both the boardlabel and of the area with the chips....
    07-18-2025, 08:03 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
