SRF10100C 100V 10A Dual Schottky Barrier Power Rectifier
  • MegaOne302
    • Apr 2009
    • 94
    Anyone knows where to find this part?
    I was thinking of just using two 100V 5A single Schottky diodes.
    What you guys think?
    Thanks,
    Joe
    Does an idiot make a sound if no one’s there to hear them talk?
  • MegaOne302
    • Apr 2009
    • 94
    Re: SRF10100C 100V 10A Dual Schottky Barrier Power Rectifier
    Will this part work?
    • PlainBill
      • Feb 2009
      • 7034
      The electrical specs are close enough. The problem is the mounting tab. The original has an insulated tab, the replacement you want to use has the tab electrically connected to the center lead. Depending on the topology of the heat sink (most are connected to ground), you will have to use an insulating pad (mica or silicone) and an insulated washer.
      PlainBill
      • MegaOne302
        • Apr 2009
        • 94
        Hi Bill,
        Thanks for the replay…
        I had to get this LCD going ASAP so I subbed the SRF10100C (after all, its 2 Schottky diodes in one package). I used 4 SR3100 3A 100V schottky diodes running 2 parallel sets of 6A 100V for each leg. Let's see how long it holds.
        Thanks guys,
        Joe
        • MegaOne302
          • Apr 2009
          • 94
          Update, don't think it's going to hold. The diodes may be too slow; I'm getting minor pulses on the screen itself.
          • MegaOne302
            • Apr 2009
            • 94
            Looks like I made a mistake; just dropped the refresh rate down to 60Hz from 70Hz and the LCD is doing fine.
            • PlainBill
              • Feb 2009
              • 7034
              I would expect that. It is rare to find a LCD montor that requires more than 3 A on the 5 VDC supply. This would be a short term solution, however. The diode is mounted on a heat sink for a reason.
              PlainBill
              • Toasty
                • Jul 2007
                • 4171
                I don't believe you can parallel Schottky diodes. Minor differences in switching speed between them are additive.
                Toast
                veritas odium parit
                • Wizard
                  • Mar 2008
                  • 2296
                  For this reason I get horrible quality on DC waveforms with 3 dual-diode full-wave like that in parallel for 24V supply in one LCD. I think this what blew the chipset because this one oddly used 24V to 2 buck regualators for 5V supplies, where one would use decent seperate supply circuit to pump 12V and 5V direct from SMPS and keep 24V noisy seperate for the backlighting.
                  Stranger things happened. :P
                  Cheers, Wizard
                  • MegaOne302
                    • Apr 2009
                    • 94
                    So far, it's been on around 24 hours at 60Hz with no noticeable problems.
                    I think the diodes are switching too slow.
                    Can this be why the LCD won't do 70Hz or above?
                    • Gianni
                      • Jul 2008
                      • 681
                      • Italy
                      That's right. The Vf changes quickly with temperature so the diode with lower Vf takes more current, it heats up lowering its Vf so taking more current... this goes on until it takes all current and maybe it destroys itself.
                      It is different for diodes like SRF10100C or MBR10H100CT, the junctions are on the same die/body so the Vf is almost the same and if the temperature increase both Vf junctions drop.
                      Another replacement for SRF10100C could be STPS10H100CFP, the body is already insulated.
                      Ciao
                      Gianni
                      "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                      H. J. Brown
                      • MegaOne302
                        • Apr 2009
                        • 94
                        Hi Gianni,
                        The SR3100 I used has the same 0.85 Vf as the SRF10100C. But I do understand what you're saying about the junctions causing resistance. Is the Ir better on the (SR3100 30ma@125c) then the (SRF10100C 10ma@125c)?
                        This is why I love electronics, the learning never ends…
                        Thanks for the Sub P/N,
                        Joe
                        • Gianni
                          • Jul 2008
                          • 681
                          • Italy
                          Ir= reverse current.
                          Low value is better than high value because it causes power dissipation when the diode is reversed polarized (Pwaste=Ir X Vr).
                          Obviously the wasted power increase at higher frequencies.
                          For SRF10100C the 10mA is for one diode, so the total Ir at nominal Vdc and 125ºC is 20mA using both diodes.
                          Ciao
                          Gianni
                          H. J. Brown
                          • MegaOne302
                            • Apr 2009
                            • 94
                            Thank you
                              HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                              This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                              09-12-2024, 02:00 PM
                              STPS3045CT STPS3045CG STPS3045CG-TR STPS3045CW Datasheet
                              The STPS3045CT STPS3045CG STPS3045CG-TR STPS3045CW Power Schottky Rectifier
                              Dual center tap Schottky rectifier suited for switch mode power supply and high frequency DC to DC converters. Packaged either in TO-220AB, TO-247, or D2PAK, this device is especially intended for use in low voltage, high frequency inverters, free wheeling and polarity protection applications.
                              STPS3045CFeatures
                              ● Very small conduction losses
                              ● Negligible switching losses
                              ● Extremely fast switching
                              ● Avalanche rated
                              ● ECOPACK2 compliant component for...
                              10-07-2024, 04:30 AM
                              Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                              by momaka
                              This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                              Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                              Macron Power Technology Co. LTD.
                              Let’s look at the PSU itself.
                              The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                              06-02-2021, 10:05 PM
                            • magistertc
                              CMOS battery drains quickly
                              by magistertc
                              This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                              as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                              Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                              Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                              configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                              07-06-2024, 09:55 AM
                            • Steph.hen
                              Bridge rectifier identification part number KPB305G
                              by Steph.hen
                              Hi all, a newby question about a bridge rectifier I'm trying to identify.
                              I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                              08-29-2024, 09:52 AM
