AG neovo F-419 first time fixing LCD
  • Mark369
    • Jul 2009
    • 163
    Hi my 19" LCD just stopped working.
    I have opend the cover and found two bad caps and replaced them
    the caps are Elite 470uF 25V 105 now the the screen just blinks no single for a split second. can any one help?
  • PlainBill
    • Feb 2009
    • 7034
    Re: AG neovo F-419 first time fixing LCD
    One of the facts of life - not all bad caps have visible problems. Elite is one on the extensive list of bad cap manufacturers. Replace the rest of the caps. I suggest Panasonic FC series from DigiKey.
    The 'No signal' for a split second has a number of possible causes. One is that there are still bad caps. Another is a cable or cables not properly seated. A third is a solder splash while replacing the caps. Another possible cause is a cable broken when unplugging it.
    PlainBill
    • DrvLikHell
      Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
      by DrvLikHell
      Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
      The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
      07-05-2024, 02:54 AM
    • titomno2
      Gaming Laptop Zephyrus S17 TFT not detected every time !
      by titomno2
      Hi guys,
      I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
      So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
      On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
      Then the screen won't work for a long period of time.
      If I wait 1 or 2 hours it work again most of the time.
      When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
      01-19-2025, 08:27 AM
    • flat-earther
      Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
      by flat-earther
      I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
      To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
      I have opened the camera and I think there is enough room to add something inside to accomplish this:
      The camera is powered by a 3.7V nominal single cell lithium ion battery.
      So I need to connect another battery in...
      06-08-2025, 02:00 AM
    • OscarAV
      HP Pavilion dm4-1065dx long time to get the power led on
      by OscarAV
      I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
      I have made a quick search for my laptop but I have not seen anything similar.
      I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
      09-23-2024, 05:53 PM
    • BigOof
      Pioneer RM-07 Active monitors cutting out from time to time
      by BigOof
      I have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
      12-18-2024, 04:35 AM
