Acer 19" working?
  • bcuda
    • Jun 2009
    • 7
    Acer 19" working?
    I am using an Acer AL1916W right now. I am trying to decide if I should open it up and change the caps or wait until it fails. I hate to mess with something that is working but I also hate not to prevent a failure. I don't leave my computer on so it only gets used a few hours a week. It's about a year old i think.
    Any opinions?
    Thanks,
    Bob
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Acer 19" working?
    how good are you at soldering?
    sigpic
    (Insert witty quote here)
    • bcuda
      • Jun 2009
      • 7
      Fair i guess. I just got a Westinghouse 19 recapped. That's why I'm asking. I'm definately not great at desoldering. All I have is a spring type tool.
      Bob
      • EGuevarae
        • Nov 2008
        • 1336
        Bob
        Better do it now. If you wait, any bad cap(s) in there can take something else when they go south ....
        It will be practice anyway ....
        There are 10 kind of people in this world: those that understand binary, and those who don't.
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • 16gb GSKILL TridentZ RGB DDR4-3200
        • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
        • Windows 10 Pro x64
        • GeForce GT1050
          2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
        • aico60
          Acer Nitro 5 AN515-46 DMI not working
          by aico60
          I am working on an Acer Nitro 5 AN515-46, board HH51R LA-M002P Rev: 1A with an AMD CPU and Insyde Bios rev 5.
          Short issue description: BIOS does not recognize any of the DMI data.
          History of the laptop:
          The seller of the laptop said that it shut down during a BIOS update.
          I bought in in a condition where it turned on but did not post.
          While waiting for my RT809F to arrive, I tried to perform a Crisis recovery, which messed up the EC firmware, so... the laptop stopped even turning on. Power and Charging LEDs didn't work either...
          05-06-2025, 08:44 AM
        • Simon Halley
          Need working bios for Acer Nitro 5 AN515-56
          by Simon Halley
          Needing a working bios for an Acer Nitro 5. Help would be really appreciated.
          AN515-56-58EE
          Model: N20C1
          Serial No: NHQBZSA00112003B723400
          SNID: 12001521834
          Mainboard: GH52T LA-L051P
          Rev: 1A
          2021-01-25
          (see attached, the non-working bios)...
          08-11-2025, 03:09 AM
        • titomno2
          Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
          by titomno2
          Hi guys,
          On motherboard ACER AN515-52 type LAF951P.
          I fixed issue with not starting computer (it was the PQ201 component not working properly).
          But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
          Basically some HDD spin but are not detected by the bios.
          โ€‹
          Already tried following:
          checked the 4 data lines
          #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
          #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
          07-28-2024, 08:30 AM
        • abrahim110
          [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
          by abrahim110
          ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
          I have an Acer Aspire 5 A517-52G-53NB laptop.
          The onboard (soldered) RAM was faulty, so I physically removed the chip.
          I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
          โœ… System status:
          • BIOS mod is done (SPD removed)
          • Laptop boots to Windows normally
          • RAM is detected and stable
          โŒ Problem:
          The battery is not charging:
          • Power adapter
          08-06-2025, 06:15 AM
        • Thunderace7
          Acer Nitro N50-640 USB not working.
          by Thunderace7
          Hi.
          I have an Acer Nitro N50-640 that has been downgraded by fitting a Core i3-12100F processor and a Radeon RX560 graphics card. I am running Windows 11 Home.
          There are 6 USB ports on the back of the machine (2 blue, 4 black), and 1 red USB and a USB-C on the front of the machine. I believe that all of these are mounted directly on the motherboard.
          The red port on the front of the machine has stopped working whilst all the others are OK. I have tried eveything in software that I can think of, including uninstalling the USB Controllers in Device Manager and letting the PC...
          06-28-2025, 09:05 AM
