Dell P2417h Vertical lines
  • jbcmd4
    • Oct 2018
    • 3
    Got a Dell P2417h monitor that is pulsing white vertical lines. It was working fine then after a bit starting fading black from right to left. Now without any input pulled in it does the pulsing white vertical lines. I have changed the power board with one I got from ebay. Was going to buy a main board but wanted to see if anyone had any ideas. I'm thinking maybe it a bad panel. Thank you for your help.
  • raptor22
    • Apr 2019
    • 6
    • Pakistan
    Re: Dell P2417h Vertical lines
    did you got it fixed?
    • 202020
      • Oct 2020
      • 7
      • Malaysia
      This should be panel related problem, not fixable unless u have tab bond machine to change the COF.
      • Stanley1843
        by Stanley1843
        06-29-2024, 11:54 AM
      • Falki
        Colorful LCD Vertical Lines on Samsung ue55es8090
        by Falki
        Hello there, ive recently found an older 55inch Samsung SmartTV.
        A similar issue has been posted as well but also with no actual response ...
        08-12-2025, 04:19 AM
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
      • atticus_
        Dell U2518D strobing/flashing with vertical lines
        by atticus_
        I dumpster dived a 1440p Dell U2518D screen the other day and figured I'd take a crack at fixing whatever issues it may have. I powered it up to find that even with no signal input the screen flashes rapidly when turned on and has vertical lines across it. I disassembled the monitor and took pictures of the 3 circuit boards inside it along the way.
        The three circuit boards are labeled "power board l6256-1m", "LED Driver BD L6257-1". and "Interface Board L6127-1". if anyone has schematics for any of them it would be much appreciated...
        06-16-2022, 02:49 PM
      • gpo23
        Sony KDL-40V3000 - Vertical lines
        by gpo23
        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
        With the new t-con the color are good but there are vertical lines on all the screen :
        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
        Is there a way to fix the vertical lines on the new t-con ?
        gpo23...
        10-04-2023, 09:11 AM
