Samsung 910t
  • IRShifty
    • May 2009
    • 78
    Re: Samsung 910t
    Originally posted by Wizard
    Can we have detail again?
    What capacitors are used to replace and did this PSU get complete do-over with electrolytic capacitors? Little ones too.
    Cheers, Wizard
    Capacitors haven't been changed at all, replacements are in the mail.
    Also: Can I use bipolar capacitors instead of general purpose ones?
    • EGuevarae
      • Nov 2008
      • 1336
      Re: Samsung 910t
      You can not use GP caps on this kind of application (I mean, you can, but you should not). As for bipolar, I don't know.
      Post something like this also : with (-) probe of DMM on pin 5 (either way, it is GND from top to bottom or bottom to top, is the middle one )
      1.-
      2.-
      3.-
      4.-
      6.-
      7.-
      8.-
      9.-
      Tha would help.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • PlainBill
        • Feb 2009
        • 7034
        Re: Samsung 910t
        There are several reasons for not using bipolar caps. They would be larger, more expensive, less likely to be available in low esr ratings, etc, etc. I won't go into the implications of having a schizophrenic power supply, a monitor with manic - depressive tendencies, or the other bad jokes possible.
        PlainBill
        • IRShifty
          • May 2009
          • 78
          Re: Samsung 910t
          12v
          12v
          gnd
          gnd
          gnd
          5v
          5v
          0v
          -100v
          • PlainBill
            • Feb 2009
            • 7034
            Re: Samsung 910t
            12v
            12v
            gnd
            gnd
            gnd
            5v
            5v
            0v
            -100v
            Something is wrong here!! Operator error?
            PlainBill
            • IRShifty
              • May 2009
              • 78
              #26
              Re: Samsung 910t
              That is what i was confused on. Checking the voltage the same as i did the rest of the pins, This one went negative and kept changing to different readings all around -100. I am confused as well.
              • kikkoman
                • Jul 2007
                • 691
                #27
                Re: Samsung 910t
                service manual:
                just opening didn't work for me, you have to 'save as...'
                "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Re: Samsung 910t
                  12v
                  12v
                  gnd
                  gnd
                  gnd
                  5v
                  5v
                  0v
                  -100v
                  That pin, in my case, is/was the BLON signal. It has voltage only when connected to a VBoard and with valid signal. The pin before it (the one you put 0v) was varying, so I guess it is/was the dimmer.
                  The PSU was connected to the VBoard or not?
                  • GeForce GT1050
                  • IRShifty
                    • May 2009
                    • 78
                    #29
                    Re: Samsung 910t
                    No it was not, i can get new voltages with the vboard in a little bit.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Re: Samsung 910t
                      See page 9-1 (page 45) on the mentioned service manual. There's the connector pinout with the voltages that are/must be present.
                      • GeForce GT1050
                      • IRShifty
                        • May 2009
                        • 78
                        #31
                        Re: Samsung 910t
                        • IRShifty
                          • May 2009
                          • 78
                          #32
                          Re: Samsung 910t
                          With the vboard i am getting:
                          12V
                          12V
                          gnd
                          gnd
                          gnd
                          5V
                          5V
                          47mV
                          8mV
                          • kikkoman
                            • Jul 2007
                            • 691
                            #33
                            Re: Samsung 910t
                            pin 9 (BL_EN) should read 5V if switched on... but hey, it doesn't matter at all since your backlight works anyway.
                            pin 1 and 2 should be more like 13 or 14V according to the manual but i doubt that's the issue.
                            have you checked with both analog and DVI inputs?
                            if you have a scope, you could follow the manual (no input signal).
                            • Wizard
                              • Mar 2008
                              • 2296
                              #34
                              Re: Samsung 910t
                              Dimming voltage (adj_BL) should be around 2.5 to 3.xV, The BL_EN is backlight enable pin which should go up to appox 2.5V ~ 5V (positive). I'm sure.
                              Cheers, Wizard
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Re: Samsung 910t
                                12V
                                12V
                                gnd
                                gnd
                                gnd
                                5V
                                5V
                                47mV
                                8mV
                                The manuals says 14v,, however I too measured 12v on that pins.
                                The last pin, the BL_ON line, showed 5v with valid signal attached.
                                That goes on for about 10 sec and then it goes black and then the screen is populated with colored vertical lines
                                I've seen a similar behavior, but the screen ended completely white. That was caused by a short that left the BLON signal always on. If you turned off that unit, it would do that.
                                If you connect valid signal to it, it must display something. The unit I had that used to shut down itself after a valid signal was applied, was fixed by changing only one cap, the (1) in my crappy schematic/drawing, as per PCBONEZ instructions.
                                Measure the BLON line with valid signal attached.
                                • GeForce GT1050
                                • IRShifty
                                  • May 2009
                                  • 78
                                  #36
                                  Re: Samsung 910t
                                  With a valid analog signal attached but the back lights detached, I receive 3.7V from the BL_ON pin. Once the monitor stops searching for signal the power LED is still green and the voltage drops to 8mV. A few seconds later the monitor is still on but the power LED goes out.
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Re: Samsung 910t
                                    Someone on a VP201b thread took a video of teh unit's behavior and uploaded it to youtube and posted the link. Can you connect all together, apply valid VGA signal and do teh same? I'm really confused.... (both with signal and without signal applied if possible) ...I ran out of suggestions.
                                    • GeForce GT1050
                                    • joshuashsong
                                      • Sep 2009
                                      • 3
                                      #38
                                      Re: Samsung 910t
                                      My Samsung 910T with MJ19BS IP Board is having the following problem:
                                      Once power on, the monitor will show a small screen on the upper left corner showing "Digital/Analog", after a while, it will display "check signal cable" - analog / digital depending on the source selected. If the VGA 15pins or DVI-D cable is connected, the monitor will goes drak & blank, & switch to sleep mode. When press the "Menu" button, it will show "Test Good".
                                      I have follow your suggestion & measure the voltages on the CN600 when the signal cable is not connected. The screen show "Check signal cable"
                                      Pin 1 - 12.3V wrt to pin 5
                                      Pin 2 - 12.3V wrt to pin 5
                                      pin 3 - 0V
                                      pin 4 - 0V
                                      pin 5
                                      pin 6 - 5.02V
                                      pin 7 - 5.02V
                                      pin 8 - 50mV
                                      pin 9 - 3.36V
                                      If the signal cable is connected & the monitor goes into sleep mode, CN600 voltages are:
                                      pin 3 - 0V
                                      pin 4 - 0V
                                      pin 5
                                      pin 6 - 5.02V
                                      pin 7 - 5.02V
                                      pin 8 - 50mV
                                      pin 9 - 0V
                                      I have tried replacing the 470uF 25V capacitor on the IP board as per your previous response, the problem still remained unchanged. Please help.
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Re: Samsung 910t
                                        pin 3 - 0V
                                        pin 4 - 0V
                                        pin 5
                                        pin 6 - 5.02V
                                        pin 7 - 5.02V
                                        pin 8 - 50mV
                                        pin 9 - 3.36V
                                        pin 3 - 0V
                                        pin 4 - 0V
                                        pin 5
                                        pin 6 - 5.02V
                                        pin 7 - 5.02V
                                        pin 8 - 50mV
                                        pin 9 - 0V
                                        Post pics and cap info.
                                        • GeForce GT1050
                                        • lucky13
                                          • Aug 2007
                                          • 412
                                          #40
                                          Re: Samsung 910t
                                          If you can see the message box, then your backlights are working and the problem is likely not the power+inverter board. The problem would likely be the main/signal board (where your VGA connects to). There maybe a couple of voltage regulator ICs on it dying... post some pix of it here.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
