Samsung P2770H monitor, on/off issue
  • wkx
    • Sep 2018
    • 9
    • Argentina
    I have a 27 inches Samsung P2770H monitor. Since a few months ago it started having this issue where it would turn off and then turn on after 2 seconds (monitor would completely turn off not just backlight).
    It mostly happened when watching a video on full screen, but it happened a few times just using a web browser or writing in vscode. And once it happened, it would happen again every few minutes.
    I first thought it was the power supply (it uses an external 14v 3.5a brick), so I replaced it and the issue continued. Someone told me to check the inverter transformers, the board (BN44-00308C) has 4 of them, they all measured the same resistance with minimal variation. So I checked the tcon board (not sure if thats the right name, the board where you connect the power and dvi/hdmi input). And found this:
    it doesn't show well in photo, but in the back side of the board, in the position where the MP2372DN is, it's really brown from the heat. I did a little experiment, and placed a tiny piece I cut from an aluminium heat sink with some thermal paste (ended up being just a block of aluminium without fins because otherwise I coulnd't close the board metal enclosure).
    It's been two days and I watched 3 movies and some long youtube videos on full screen without having any issue. So I am assuming the issue is caused by the MP2372DN overheating (the datasheet does says that it has a thermal shutdown protection).
    Has anyone seen this type of issue with these kind of regulators?
    My doubt is if I should change the MP2372DN (which only seems to be available from china and who knows what the quality it is), or if there could be some other component causing it to overheat.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Samsung P2770H monitor, on/off issue
    Hard to tell if it's the MP2372DN that is faulty or if there is another faulty/marginal component. You'll probably need to draw/trace a full circuit diagram for that regulator to see what it is powering and what's feeding it power. Not impossible for some ceramic cap or something else to have aged too much and dropped a bit more in capacitance. But it's also possible the MP2372 regulator is starting to go.
    Another approach would be to see if you can add more ventilation holes to the monitor chassis to allow the board to cool better. Maybe even consider adding a small heatsink on top of the regulator with thermal adhesive (kind of what you have now, but cooling the chip a bit more directly). Not a great solution, but an option nevertheless.
    I'll wait and see what other members have to say here, though. Maybe someone might have a better idea.
    • wkx
      • Sep 2018
      • 9
      • Argentina
      The monitor is still working with the "heat sink" mod and haven't experienced the issue again so far. I still wasn't able to find the MP2372 locally, overheating does seem to be the issue. If I ever need to buy some stuff from china I'd probably get a few MP2372DN and try to replace it anyway.
      • mauricioentraigas
        • Feb 2021
        • Argentina
        @wkx Hola man, veo que sos de argentina asi que lo escribo en español jaja, tengo el mismo problema, En mi caso se calientan 3 chips de la placa(entre ellos, el mismo que a vos). Al día de hoy sigue funcionando tu monitor con el radiador que le metiste?
        Hello man, I see that you are from Argentina so I write it in Spanish haha, I have the same problem, In my case 3 chips on the board get hot (among them, the same as you). To this day your monitor is still working with the radiator that you put in it?
          • 21669
          Write only in english please
          • Hauzer
            • Nov 2021
            Thanks for posting this, I had the same problem but actually had 3 chips that looked they were overheating on the back of the board. I went ahead and put little memory/mosfet heatsinks on all 3 and cut out holes in the plate so they would fit and get some more air.
            It's been working perfectly now for a couple weeks, before it was to the point where it would work for about 5-10 minutes then start cutting off every couple seconds until I let it cool down again. I've been using it as a 2nd monitor for videos/browser etc.
            Another tip for people with this problem: put the response time on Normal, this fixed the problem for me for a long time, but it still started happening again to where I couldn't use it for games, then video, then anything really... so it's probably best just to add some cooling asap.
            • Kjell
              Samsung Series 9 - BIOS issue
              by Kjell
              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
              08-01-2025, 09:15 AM
              09-07-2024, 05:50 AM
            • Nairolf
              Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
              by Nairolf
              I have a Samsung DM32D display.
              When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
              Here’s what I have tried so far:
              1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
              2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
              3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
              From these tests, I suspect the problem might be on the mainboard. Could anyone...
              08-24-2025, 03:47 AM
            • Manucsl
              QE65Q800TATXXC Samsung TV Issue
              by Manucsl
              Hello.
              My TV is a QE65Q800TATXXC Samsung TV.
              Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
              Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
              Any ideas to check would be very appreciated 😊
              After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
              02-19-2025, 07:47 AM
            • FourRunner
              Display issue Samsung TV UA65JS9000W
              by FourRunner
              I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
              10-03-2024, 07:05 PM
