Dead Power Supply(XAD819AR) for Acer AL1706
    Re: Dead Power Supply(XAD819AR) for Acer AL1706
    Hi, This thread helped me repair my Acer AL1706b. The power supply is different than the one shown and it uses different capacitors, so I have attached an annotated picture with the caps identified. I ordered the caps needed from Digikey -- with one exception. They do not stock the 22uF, 25 V cap. Also note, in the picture, two caps are identified as C244; the upper one is 244, the lower one is C241 .. they are the same size and voltage.
    If anyone knows the size of the fuse on these power supplies, I would like to know, just in case ...
    Hope this posting helps someone else as much as this thread helped me. Thanks for what you offer through this site.
    Jerry
    Caps for Acer AL1706b LCD monitor.pdf
      You can use the Panasonic FC cap at
      http://search.digikey.com/scripts/Dk...name=P11213-ND
      That red circle just above the AC adapter is your fuse. It looks like 2A/250V
      --- begin sig file ---
      --- end sig file ---
        I've got an AL1706b that's completely dead - no led, no power, nothing.
        Input fuse @ 2A/250v checks out, and all caps visually look good. No leaks, no bulges.
        This is the Rev: C board dated 2005.11.04 and was working perfectly until a couple days ago.
        I know caps can look fine and be bad, but I don't want to waste my time replacing a bunch of caps to find out it's something else. It'd be one thing if I had the assortment here already, but most of these would be custom-order, which only adds to the hassle.
        Thanks!
          give us some voltage measurements.
          Al.
            Please post some good quality photos per the link below:
            https://www.badcaps.net/forum/showthread.php?p=118105
              It sounds like you have a multimeter. If you know how to use it, see if the secondary voltages, usually 5V DC and/or 12VDC, are present on the connector between the power board and logic board.
              If not, carefully measure the DC voltage across the main filter capacitor. It should be 1.4 * mains.
              Post clear focused pictures AFTER reading
              https://www.badcaps.net/forum/showthread.php?t=1868
              Please do not post pictures inline.
              Take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focus pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
              Here is an example of the pictures we want.
              https://www.badcaps.net/forum/showpo...94&postcount=1
                I'm on the way out the door to a wedding so will post more details/pics when I get back.
                Quick measurements show that both 5v leads going to logic board are good, doesn't look to be a 12v line, and there is minimal voltage (around 1v or so if I remember correctly - I don't know the spec though) on the other non-ground leads as well. Voltage at main cap is ~170v.
                Probably doesn't help without any more info though - I'll get to that when I return.
                I hate to hijack a thread - if this belongs on its' own, feel free to split it!
                Thank you.
                  Have fun dancing to the "chicken dance song" and Celebration (Kool and the Gang).
                  I was just guessing it might have 12V DC. So it looks like the power supply is fine with stable 170V DC at main filter cap and 5V DC going to the logic board.
                  I guess we will wait for the pictures.
                    Is it possible that electrolytic capacitor is defective even if its not blown up?My power supply board has the same problem it has no power led even its plug in,non in everything.I would like to try to replace all the capacitor,as of now I remove all of them to replace new ones.I hope to hear a comment as soon as possible. Thanks in advance!
                      Yes. A cap can have high ESR (ohm) or be out of uF specifications without showing signs of bloating.
                      Before replacing anything, please answer a couple of questions
                      1) Do you have a mulitmeter?
                      2) Do you know how to use a multimeter to mesure voltage and resistance?
                      Also, post clear focused pictures AFTER reading
                      Please do not post pictures inline as they slow down the loading of pages.
                      For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
                        I didn't want to hijack this thread and confuse with multiple people submitting info so I started another thread. Link
                          How come i change all the capacitors but it actually have the same result? Are you all hoax? Fooling people to sell something..... OMG! have a grace in yourself!
                            Can you read? In post #50, I suggested (note the word "BEFORE")
                            2) Do you know how to use a multimeter to measure voltage and resistance?"
                              troll?
                                Ha ha ha.....I fixed my AL1706 monitor.But its not the capacitor.....Can anybody knows about the power IC? LOL
                                  Yes,I have a multimeter and I know how to use it!OMG I found out what the problem is.....It's the power IC! Do you know about the power IC? or your not familiar with it? ha ha ha
                                    Hello guys , grats on the great site!
                                    Out of boredom I´ve opened an old AL1706 that wont turn on (just a quick flash on the led) the power board just the same that was posted on a pic on the previous page , a few caps do look bloated , measurements on the out pins 12+ :13.4v 5v+ :5.15 GND: -0.047.
                                    Would bad caps cause this kind of erroneous outputs?!
                                    Thanks in advance
                                    Aiki
                                      Thanks in advance
                                      Aiki
                                      Those voltages aren't unreasonable. The 12 volt rail normally runs high when the inverter is off, and the 5 volt rail is normally 5.2, so it's right on.
                                      However, the readings don't show how much noise is on the 5 volt rail, and if the caps are bad enough it will cause problems for the processor on the signal card. It isn't impossible that that has already happened. Sometimes if the problem persists long enough the eeprom on the signal board gets corrupted.
                                      PlainBill
                                        Hey Bill , thanks for your answer.
                                        So in your experience , a corrupt eeprom memory would prevent the unit from powering on?Think i remember having to repeteadly try to turn it on before use until it finally died.
                                        Would you suggest a replace on those caps?
                                          First of all, replace all bulging caps; better yet, replace ALL electrolytic caps on the power supply with the possible exception of the large 450 volt one.
                                          The signal card can be thought of as a special purpose computer. Most graphics processors have only a small piece of bootstrap code which loads the actual firmware from a serial eeprom. User data (brightness, contrast, current status, etc) should be stored in a second serial eeprom. When the power supply starts the graphics processor retrieves it's programming from the program serial eeprom. It then loads the 'last known state' from the user eeprom. A power supply rail with excessive noise makes writing to and reading serial eeproms prone to error. If program storage is corrupted, the graphics processor is 'brain dead'. If user storage is corrupted, some processors flash the power led rapidly to indicate a problem.
                                          PlainBill
