Samsung Syncmaster 225BW
--- begin sig file ---
--- end sig file --- -
Re: Samsung Syncmaster 225BW
I have to say thanks to the members of this forum. I have successfully repaired my 225BW by replacing the recommended caps. It was showing signs of failure and it's all good now.
Thanks!Comment
1) That different revs of the same board can use a different design, which results in different parts being used. That's why it's important to verify the part values on your board to the parts list in the cap kit before you purchase.
2) You should not use the 680uf, since it's obvious that something on the board changed, which requires the 330's.Comment
You have discovered two things:
In this case, I now have 4 nice 680UF 25V free to a good home. On to order some more 330's from Digikey. The local Radio Shack only had 220s and 470s at 35V. I even rummaged through their misc. packs as well as opened up another dead 15" thinking I may get lucky. Lo and behold, no such luck. So the long weekend project will extend out to the rest of the week.Comment
What I figured as well though I was hoping against hope.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Sadly, Radio Shack is all that's left locally here in the area of Sunny Southern California where one can go for parts. Gone are the Mar Vacs and oh, what's the name of the other store... Fry's an hour round trip away and it was too close to lunch.
Without a dedicated work bench and little ones running around, I've decided to replace what I can (2 bulging 820UFs and 2 bulding 330UFs) and button it up. The blinking has gone away and the 225BW is limping with one bulging 330UF still remained to be replaced.Comment
Hey!
You've said "You need to verify the output voltages of the supply before going any further". I need some hardware for that I'm sure. I hate radioshack, hopefully I can get that elsewhere...
Here are the requested pics:
What do you think? Are any other components toasted?Comment
Since this is just what I'm working on, I don't know if anyone else has pointed out I believe the color labeling of your connectors are incorrect (at least different than my factory connection). On mine, immediately after I disassembled it for the first time, the light blue leads are towards the outside top and bottom, and pink are on the inside.
Hey guys,
So I was about to pull the trigger on an ebay auction for a set of caps to try to repair my 225BW, http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123 , I've been working on this on another forum, http://forums.pcper.com/showthread.php?p=4497427
I'm a novice with a soldering iron, but I'm hesitant about getting bad caps. I'm a bit inundated with information at the moment. Should I bother ordering from this guy on ebay? If not, where and could someone point down exactly what?
These are the pictures of my board:
http://www.wolvenmoon.com/sharedfiles/caps1.jpg (Bottom right)
http://www.wolvenmoon.com/sharedfiles/caps2.jpg
I see digikey highly recommended here. I've never been able to figure out their site when I go there and I always get really nervous. If the ebay auction is a bit too iffy, could anyone give me direct links to what I need to order so that it'll fit? Seeing all of the model numbers in the first part of the thread has me kind of nervous about ordering the wrong thing.
I'll be cross posting what I order into the other forum thread for google's sake. (That's how I found this site)
I know it's obnoxious to have the newb come in and go 'do the gruntwork for me', I'll make sure to pass it on.Comment
http://www.youtube.com/watch?v=I_NU2ruzyc4
PCBONEZ talks about how to choose the right series at
https://www.badcaps.net/forum/showpo...47&postcount=3
and
https://www.badcaps.net/forum/showpo...30&postcount=7
PlainBill gives instructions on how to order Panasonic FM and FC caps at
https://www.badcaps.net/forum/showpo...33&postcount=2
FR is a newer version of FM.
http://search.digikey.com/scripts/Dk...25v+fr&stock=1
http://search.digikey.com/scripts/Dk...name=P14422-ND
http://search.digikey.com/scripts/Dk...25v+fm&stock=1
http://search.digikey.com/scripts/Dk...name=P10321-ND
Total 3.88 + about 2.50 USD shipping
$6.38 USD Total
Double check to ensure the cap values match yours in terms of uF, voltage, and that they fit (diameter and height).
So by DIY, you pay almost half of what it would cost. In fact, the sellers on ebay are making more than that because they buy caps in the 100s, not in the 1s.Last edited by retiredcaps; 06-03-2011, 05:12 PM.--- begin sig file ---
--- end sig file ---Comment
Hey guys,
1. Are these the proper caps for your monitor? You can determine that - he lists the value and voltage of the caps he is selling so you can easily check.
2. Are these good caps? I can't be sure; he doesn't specify the series, but there is a good chance he is supplying low ESR caps.
3. Is his price good? Well, it's pretty good - but he's making a dollar or two for something you can do yourself.
Let's do a comparison, it'll take only a few minutes.
The table below shows the values, the cost of Panasonic FM caps, the cost of Nichicon
2 ea 820uF, 25V $1.50 $1.40
2 ea 680uF, 25V $1.34 $1.38
1 ea 330uF, 25V $.50 $.45
1 ea 47uF, 50V $.34 $.48
Using Panasonic FM or FC as appropriate, the caps will cost $3.68; shipping will add $2.50 You will save about $5.00, but I wouldn't say the guy on eBay is ripping you off.
Somewhere around is a process for selecting caps I have written. Someone smarter than I came up with the one below.
From the home page at Digi-Key enter 820uF 25V FM, then click Go. That brings up the quantities, cost and availability of all 820uF, 25 volt Panasonic FM caps. Select the one you want, click on it. On the next page enter the quantity you want, click on Add To Order. At the top of the next page enter the value for the next cap, and repeat the same steps.
Sorry about the images, I am not seeing my edit button. I think the 'new member' group is preventing me from getting to the post.
Thanks guys, this helps a lot. Yes these are the proper caps for my monitor. I'm assuming out loud so you guys can correct me that the white stripe with the dashes through it signify negative polarity? (In the pictures, they're the sides of the capacitor mounts with the thicker line at the bottom)
Any advice on desoldering wick? http://search.digikey.com/scripts/Dk...1311239&k=wick Radio shack's stuff doesn't have flux on it anymore, so I figured I'd look on digikey, was easy as 1-2-confusion! I tend to prefer lead free stuff, barring solder itself, which I'll get over for one use.
I found this really basic guide to using wick, http://www.aaroncake.net/electronics/desolder.htm my solder sucker kicks much too hard to use on anything small. (It's radioshack too...I'm glad I didn't buy any of their braid)
Also, would it be completely stupid to - after seeing that video - take some sandpaper to my radio shack (lol) soldering iron tip to take the top layer of oxidation off, then tin it, and pretend nothing happened?
Thanks!Comment
The edit button times out after 30 minutes.
I believe one motherboard manufacturer goes against this convention and does it the opposite.
On the other hand, my "sort by lowest price ebay" desolder pump works great. I have used the desolder pump on about 20 monitors and it is still working fine.
The local store wanted $30 CDN while the ebay price was around $3 CDN (including shipping).--- begin sig file ---
Thanks!
I have a 20th century 40 watt iron and a 20th century dissecting pick. I heat one pin, tilt the cap as far in the opposite direction as possible, heat the other pin, tilt the cap back, which usually releases that pin, heat the original lead and the cap drops out, hopefully not in my lap.Then I heat up each pad with the soldering iron and jam the dissecting pick into the hole to displace the solder. One the solder cools, I pull the pick and move on to the next hole.
Before soldering anything in, I verify all holes are clear. Then it's a matter of starting with the smallest caps and working up to the largest. After everything is soldered in I double check orientation, trim the leads, scrub the board with a toothbrush dipped in rubbing alcohol, and let the board dry.
At that point I usually hook the boards together loosely (fasten each in place with 1 grounding screw), say a prayer to the God Faraday and plug in the power cord. If nothing goes bang, and there is no smell of smoke I open my eyes and see if the monitor is working.
I have three Samsung Syncmaster 225BW monitors. There are:
2 680uf 25V
3 330uF 25V (although one is shorter than the other two.
1 47uF 50V
All the kits I have and ordered and threads out there I find say about there being 2 820uF 25V. Do I replace the 680 with 820?Comment
Probably a different revision of the same power supply. That's why it's so important to verify the cap values against the list of the capacitor kit before ordering. Not unusual for them to differ a bit. Don't sub the 820 for the 680.Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by soopacrucialHi folks,
I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...3 Photos-
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
- Loading...
