19" LCD - No Backlight - Replaced Caps - Replaced MOSFETs
  • Braymond141
    • Mar 2009
    • 5
    Westinghouse L1975NW 19" Widescreen LCD
    Power Supply: DAC-19M005 (DAC-19M009 Later Generation)
    I get video, but still after replacing two blown caps, no backlight. Then I replaced the mosfets, no backlight.
    As far as I can tell I'm getting no voltage to the inverter, no spike at startup, nothing. Using a craftsman digital multimeter to do the checks.
    Another member, eguevarae, mentioned SMD fuses. I'm not familiar with all the different types, but I don't see any on the board that would suggest being bad.
    Any specific things I should test? Also how exactly to test too?
    I've attached two extremely large shots of the top half and bottom half of the board. Please photoshop any test procedures or components to check You can save the images and zoom around and see far better than with the naked eye!
    ***Warning; Images are 6MBs each***
    Click thumbnail
    Thanks!
    Brett
  • Braymond141
    • Mar 2009
    • 5
    Re: 19" LCD - No Backlight - Replaced Caps - Replaced MOSFETs
    PS. I already plugged in new lamps to the board... no light up. It's not the lamps.
    • Wizard
      • Mar 2008
      • 2296
      You have 3 SMD fuses, two W's and one S's. Also flip over the circuit board and give us pictures so we can see if there is other fuses.
      Must check them with ohm-meter.
      Cheers, Wizard
      • Braymond141
        • Mar 2009
        • 5
        Replaced one W fuse, now it just cycles through power, on off, on off. You can see the backlight quickly light up then off every time.
        Tested the other two fuses, they read just fine. The one W had a varying result.
        • Bobdee
          • Jun 2008
          • 461
          There is a fuse to check in the top picture , to the right edge and lower portion of picture,
          Its black with a W on it, board number F101, [ not as big as a match head ]
          you test for continuity
          also can you post pictures of other side of board
          bob
          • Braymond141
            • Mar 2009
            • 5
            Top
            http://ipccomputers.org/misc/IMG_4785.jpg
              by momaka
              03-15-2023, 10:17 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • cmlewis89
              LG 47LB5DF blown power supply board
              by cmlewis89
              Hi folks,
              I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
              09-03-2024, 07:50 PM
            • reessi
              Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
              by reessi
              Hello:
              I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
              I started on the ACER:
              Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
              All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
              I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
              10-29-2024, 11:31 AM
