Re: CTX S762G - Some Questions...
Thank you for replying. Ah, well then. So PlainBill, do you think that this could be causing the issues I'm having? Following the traces it seems that that item is in direct contact with the plug that goes to the video board. This makes me think that it could be causing problems between the video board and the power board. (The OFF signal for the lamps when the power button is pressed and the on signal to power up the video board itself) You think this sounds feasible?
Also, I'm one step ahead of you on that. I already removed the transistor and I did measure resistance but I don't have the information here at work. I will write again when I get home with the info.
