Syncmaster 2493hm : no power no blue led, need help
  • disorder
    • Sep 2015
    • 156
    • france
    hello all,
    it's my first thred on this forum, but i read it for a long time.
    i have troubleshooting with a samsung syncmaster 2493hm dysplay
    it doesn't start, sources plugged or not, and there is no blue led !
    fuses are ok, caps are looking good and values are ok on de smps with the multimeter (Farad test)
    +5v wicom is ok
    but +5v, power_en and +5v panel are not present
    on the mainboard , i have 3.3V_live and 1.8v_live ok
    r391 : no voltage
    i found for ic304 something strange but values are ok :
    -r388 : +5v on one side and only +0.07V on other side
    -but the resistance value is 2.2kohm with multimeter
    i found it very low for ic300 , don't you think ?
    if someone can help me what i have to control now .
    thank you a lot.
    Re: Syncmaster 2493hm : no power no blue led, need help
    Can you please upload good clear pictures so we can see what we are dealing with?
    "i found for ic304 something strange but values are ok :
    -but the resistance value is 2.2kohm with multimeter"
    What is the resistance reading witH ref to GND on that end of the resistor that shows +0.07V?
    Is that end of the resistor connected to IC304? Pin number?
    IC304 P/N?
    As you can see, we do not have much of the details to go by.
    • disorder
      • Sep 2015
      • 156
      • france
      hello, thank you, i'll post some pictures tomorrow.
      for ic304 and r388 i have 5v on pin 1 of ic304, and i have 0.07v at pin3, also between r388 and c302
      i have also try to force start of smps by putting a 800ohm resistor between SB and power_en : i have 24v now but no screen and no blue led .
      i think motherboard is dead, not smps.
      thank you
        Service manual:
        https://www.manualslib.com/manual/11...ng-2493hm.html
        There Voltage regulator ICs on the main board that you should check the Voltages.
        What is the history of this monitor?
        • disorder
          • Sep 2015
          • 156
          • france
          i have no clear history : before the display could power on only after 2 or 3 days plugged in. blue led was ok.
          and one day : nothing.
          i have not more informations.
          thank you for the complete schematics, i had not the voltages on lines, i will check that and come back.
          thank you very very much for help
          • euromatlox
            • Mar 2013
            • 60
            • Finland
            Please mention board number(s) (possibly something like BN44...). The same power board (and other boards) can be found in other Samsung models too.
            If I remember right, 2493HM and 245B have same power boards, either BN44-00173A or BN44-00195A. The very well known fix for BN44-00173A is to replace 3 resistors and some electrolytic capacitors (can be found in older posts in this forum). BN44-00195A is usually much harder to fix, easiest way is to use BN44-00173A instead (they are compatible). Some tips for it however is also available in older posts.
            • ivtec
              • Dec 2008
              • 1967
              Originally posted by disorder
              hello all,
              +5v wicom is ok
              r391 : no voltage
              thank you a lot.
              I have one too that i picked up on the curve some time ago and also power up with blue led and no pic,i fixed,check post #76
              check this thread,there is a lot info. https://www.badcaps.net/forum/showthread.php?t=14483
              • disorder
                • Sep 2015
                • 156
                • france
                hello, thank you guys, i will check that.
                • disorder
                  • Sep 2015
                  • 156
                  • france
                  my board is BN44-00195A , i have test some more points and find that :
                  i have soldered a 800ohm resistor between SB and power-en :
                  when i don't plug the cn600 ribbon cable i have nothingon logic board and power board is noisy
                  when i plug cn600 only i have 3.3v , 1.2v and +5vmicom line only , not other lines. the power board is not noisy
                  if i unplugged only sb and power-en from cn600 and left 5v plug, il have +5v but not +5vmicom, 1.2 and 3.3v lines.
                  thank you for help
                  • ivtec
                    • Dec 2008
                    • 1967
                    thank you for help
                    Disorder did you re-solder all solder points in the power Supply?,did you clean all that glue around components that dried and cause conduction between legs ? did you take out scraped legs on 47pF 1KV capacitor (CM809 on the schematics and resolver it back? did you follow the whole thread that i posted ,where there is many tips to fix this monitor?,
                    • disorder
                      • Sep 2015
                      • 156
                      • france
                      hi,
                      the glue is really hard to remove but yes i have cleaned that.
                      the solder joints look good but ok i will do that
                      i did't try 47pF 1 KV capacitor to resolder , i'll do
                      but my problem is not like yours, the blue led not shine, it's like the display is dead
                      thank you
                      • euromatlox
                        • Mar 2013
                        • 60
                        • Finland
                        I have once fixed BN44-00195A, what I did was to replace SI-8008HFE DC voltage regulator and then also some SMD components following these Toasty's tips:
                        https://www.badcaps.net/forum/showth...t=18966&page=2
                        I also replaced some electrolytic caps (near that Sanken 8008HFE).
                        However the fix worked only a day or two. I decided to change the whole board using BN44-00173A instead. After that no problems.
                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-07-2024, 05:50 AM
                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          09-07-2024, 05:00 AM
                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                          Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                          This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
