BenQ Q22W6 Capacitor Replacement
  • MicroBell1
    • 33
    Re: BenQ Q22W6 Capacitor Replacement
    Sorry rddube as I meant to get back sooner with those numbers but it's been a busy week. Anyway I did get a new meter and tested those points again and they are reading 396 ohms and 392 ohms which I think you referred to as Ok as they were in the ball park.
    If not let me know...but unless you have another idea or area to check on that board I guess I'll have to try constructing a CCFL tester per Budm's thread and see if those are a problem. Was really hoping those bad capacitors were the problem but it looks like something else and with all the new meter, new soldering tools..etc this project is becoming cost ineffective.......lol
    I still have some questionable solder joints to go over and re-float but I'm not pinning any high hopes that it's the issue but we will see. Thank you for all your input and advise on this issue!.
    Any clue what those 2 transformers (L602, T601 on the board) should read on the pins?
    • rddube
      Aspiring Expert
      • Jun 2013
      • 950
      The transormers seem to be good, I was getting 450 ohms on one of the monitors I fixed. I am starting to thing that one of your CCFL tubes is probably drawing too much current and is shutting the protection chip down.
      You can try the refloat of some solder joints (it did the job for me on another repair), but ultimetaly if you can test the CCFL's (you only one spare to test) I think you will have crossed out or confirmed that the problem is there.
      Let us know.
        Make two of these test lamps to verifiy if your power supply/inverter board is OK or not:
        https://www.badcaps.net/forum/showthread.php?t=19987
        • rddube
          Aspiring Expert
          • Jun 2013
          • 950
          Hey Budm! You need to make 2 test lamps? How do you check each ccfl individually, is there a special sequence?
            If the board has four lamps, one pair for top edge, and another pair for the bottom edge then you will disconnect one of the two pair of the lamp and put the test lamps and fire up the board to see if the lamps will stay on, if it does then you know that one set of the original is good.
            There is possibility of have one bad lamp in each pair of lamp assembly, so you will need 2 pair of test lamps or you can try using combination of lamps hookup to narrow down but that takes too much time for me, I have many test lamps so it is not a problem for me to use all 4 test lamps first to verify that the power supply/inverter board is good or bad.
            • MicroBell1
              • 33
              Always a "Teach'en"moment when budm stops by.... Thanks for the info guys and I'll try and test those CCFL's soon but might be a few days as I'm in the middle of a "Pool" rehab for the summer.
              budm.... I'am assuming by "Pairs" you mean test the top 2 together and then the bottom 2? Not one of each...Correct?
                "budm.... I'am assuming by "Pairs" you mean test the top 2 together and then the bottom 2? Not one of each...Correct?" Yes, substitute the top two first with the two test lamps to see if the backlights will stay on or not.
                  HP Elite Elite Slice Elite i3-6100T Specification for Upgrade or Repair
                  This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:44 PM
                  HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                  This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                  HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                  This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
