Samsung 2235BW disabemly?
  • ron350
    • Feb 2014
    • 296
    Once the plastic back and stand are removed how do you get to the circuit boards without damaging the ribbon and cables.
  • rddube
    Aspiring Expert
    • Jun 2013
    • 914
    Re: Samsung 2235BW disabemly?
    Hi, although this is not your exact model, you might find some information in this service manual (I couldn't find your exact model, but that is the way it is with free service manuals, they are not all available) that will help you out.
    Hope it helps! Let us know.
    • ron350
      • Feb 2014
      • 296
      Rddube thanks for posting the PDF manual I was able to remove the power supply board.
      I don’t understand why the steel box that holds the circuit boards is not attached to any thing it is just held in place by the plastic back of the monitor.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 914
        OK, so what is your problem with this monitor?
        • ron350
          • Feb 2014
          • 296
          Nothing is wrong with it yet I just wanted to see whose caps are in it.
          • rddube
            Aspiring Expert
            • Jun 2013
            • 914
            And what brand are they?
            • ron350
              • Feb 2014
              • 296
              My old monitor died so I hit the thrift store looking for a replacement. I saw the worker set the Samsung 2253BW on the shelf so I grabbed it and tested for a screen saver and bought it.
              The monitor looks like new inside and out so I was shocked to find out it was made in 2007. This is why I removed the power supply to check the condition of the caps which all look like new.
              C107 47 x 50v Samwha XC
              C108 820 x 25v Sam Young NXB
              C112 820 x 25v Sam Young NXB
              C114 10 x 16v Sam Young NXB
              C115 1000 x 16v Sam Young NXE
              C116 1000 x 16v Sam Young NXE
              C118 10 x 50v Samwha XC
              C119 330 x 10v Sam Young NXB
              Inverter caps
              C301 820 x 25v Samwha XC
              C302 820 x 25v Samwha XC
              I have read several old posts here where bad caps cause the two surface mount inverter drives to short. It would be nice to know which caps cause the sm fet's to fail?
              • ron350
                • Feb 2014
                • 296
                I apologies I posted the monitors part # wrong.
                This is a Samsung 2253BW monitor.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 914
                  Well here is the service manual for your monitor.
                  • ron350
                    • Feb 2014
                    • 296
                    Which WinRAR do I need to buy to open that manual?
                    • gabiz_ro
                      • Mar 2011
                      • 167
                      • Romania
                      Works fine with winrar 3.93
                      Some new rar archive found to be incompatible with older version also with some zip.
                      You can use 7zip it's free.
                      • ron350
                        • Feb 2014
                        • 296
                        Thanks for the help guys but I cant open that file with 7zip and they want $26 to buy winrar.
                        This old XP computer is full of bugs and some times things just wont work. I have been trying to down load that manual for the last 8 hours.
                        • rddube
                          Aspiring Expert
                          • Jun 2013
                          • 914
                          Here is an unzipped version (unrared).
                          • ron350
                            • Feb 2014
                            • 296
                            Rddube thank you for going to all that trouble to help me with the service manual.
                              09-07-2024, 05:50 AM
                            • DXseekerMO
                              Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                              by DXseekerMO
                              Hello everyone!
                              Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                              Symptoms:
                              1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                              2) TV does not appear to turn on
                              3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                              4) "Power on" terminal on Power Supply has 3.26v
                              5) "A13V" terminals have 12.9v
                              6) Stand-by test jumper on Power Supply has 12.9V
                              7) Optical audio jack on Main Board illuminates
                              8) With stand-by...
                              06-09-2021, 12:19 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
