Benq G2255 doesn't power on - amber power light when plugged in - part 2
  • rddube
    replied
    Re: Benq G2255 doesn't power on - amber power light when plugged in - part 2
    Hi Will,
    If I remember well, I think I got it here:
    http://**************/forum/54-31467-1
    I registered and passed the test to be able to download the firmware.
  • will62
    replied
    On post#4, you're doing this to learn, and that would definitely kick the learning up a notch. I would recommend trying to find a 24c16 on a another board, and experiment with it. I wouldn't erase the eeprom on this board until you are confident that you can get a copy of what is on it. Be aware that only a few Arduino models have a 3.3V signal voltage. Probably not a problem on this eeprom, but it would be for the flash. You might need voltage dividers.
    Can you give me the link to where you got the .bin file?
  • rddube
    replied
    Do you think it could be worthwhile trying to do what I mention in post #4, on board?
    As soon, as I get the board back together that small cap is giving me a headache, I can hardly see it, I will try freezin the flash and EEprom and see what that does.
    Will report probably tomorrow night. Tks Will!
  • will62
    replied
    Yes, the eeprom could be checked next. I've included the datasheet below.
    Pins to check:
    5 - SDA (data)
    6 - SCL (clock)
    8 - VCC
    Here's something I found on a BenQ similar model:
    1.) DDC (Display Data Channel) function: We use DDC IC to support DDC2Bi function. DDC data is store in 24C02 (EEPROM). Those data related to LCD monitor specification. PC can read them by “SDA” and “SCL” serial communication for I²C communication for DDC2Bi.
    2.) Scalar IC: TSUMU58NWHJ-LF-1 is a total solution graphics processing IC for LCD monitors. It is configured with an integrated triple-ADC/PLL, an integrated DVI receiver, a display processing engine, an integrated micro-controller and output display interface that can support LVDS panel interface format. And it also integrates power management control capability for green-mode requirements and spread-spectrum support for EMI management.
    3.) EEPROM: We use 24C16 to store all the adjustable data, user settings and use 24C02 to store D-SUB and DVI EDID data.
    4.) Flash ROM : We use 2M bit flash to store the FW hex.
    I would think that the led would change from amber once the firmware was loaded from the flash.
    Added:
    Maybe try freezing the eeprom and flash. Watch about 6:20 in to this video:
    https://www.youtube.com/watch?v=kPCisa9BYkk
  • rddube
    replied
    Yes, you're right. One of the guys in that thread says he baked the board in the oven!!
    Ok, so I'll put everything back in place (mosfet and capacitors) and maybe try and do some more tests on the flash. What about the EEprom, is there any way we can check that? It's getting voltage ok.
    Would the main chip communicate with the flash if the EEprom was wiped or erased?
  • will62
    replied
    Read the thread below. OP had power rail with 65 ohms to ground. Some thought that indicated a short on the CPU. OP replaced board. The new board also had low ohms to ground, but worked.
    The 85/40 on your board may be normal. This gives me pause on jumping to the conclusion that the main chip is bad.
    https://www.badcaps.net/forum/showth...t=36494&page=2
  • will62
    replied
    My best guess is that the problem is with the TSUM chip. We can't be for sure that the 40 & 85 ohms to ground is a problem for that chip, but the lack of a good clock and data signal to the flash, points to the chip. I'd be more certain if your scope had higher bandwidth, but that's the best tool you have available to check it with.
    Before ordering, you could go back and try different settings on your scope to make sure that clock and data signals are absent. On your scope, signals should look similar to the crystal (but brighter). If you get different results, problem would shift to the flash chip.
  • rddube
    replied
    Hi Will, resistance between 3.3v and 1.8V rails is 118.3 ohms (looks like the sum of each rail?).
  • will62
    replied
    I'm thinking that it is the chip. I'll look back over the schematic. In the mean time, please give me the resistance between the 3.3V and 1.8V rails.
  • rddube
    replied
    Ok Will, took out the mosfet (still low ohms, so removed C85, C86 and C87 and it's still at 82 ohms on the 3.3V rail and 42-43 on the 1.8V rail.
  • will62
    replied
    All of your filter caps are in parallel. You'll probably read that 85 on all of them.
  • rddube
    replied
    ok, I'm in it for real! Will, what about C530, I also get 80ohms on that one too (haven't started yet on the mosfert and the other caps)?
  • will62
    replied
    Just watch some videos on drag soldering. If it turns out to be the chip and you order it, you'll have 2-3 weeks to practice before it arrives. Practice on your junk boards. Wick off as much solder as you can from a chip and practice your drag soldering.
    If the regulator checks out, do you think that you'd be able to lift single pins on the chip? I don't think I've ever attempted lifting them on fine pitch chip like that. Maybe using the tip of an exacto knife as you heat the pin? There's only 18 power pins, and if you choose wisely, you may only have to lift 1.(LOL)
    If you are going to replace it, most people cut all the pins from the chip, then remove each pin from the board.
  • rddube
    replied
    Ok, I'll get to that asap. Just curious however, when you say the chip is causing it, do you mean the big 128 pin chip? Oh boy, if that is it, then I'm in for a real contract to change that chip...I'll definitely need your moral support!
    Will get back to you with my findings soon. Tks Will.
  • will62
    replied
    OK, it is accessing the flash, attempting to load the hex code, unable to do so, then staying in a loop trying. If you had a good clock and data in signal, it might be the flash chip with the problem. Doesn't sound like you have either.
    At this point, I think we need to try to resolve the low ohms to ground issue with the 3.3V and 1.8V. The 1.8V is the chip's core voltage. It goes nowhere else on the board. The only 2 places the 2 voltages are in close proximity is at the voltage regulator and inside the chip. I would start by removing the U12 regulator. Recheck ohms, if still low, remove filter caps C85,86,87.
    If you still have low ohms, I'd be willing to bet that the chip is causing it. It is available on ebay for $7.99.
  • rddube
    replied
    It stays low, with the spikes every 2-3 seconds....I left it on for about 30 seconds to see if it would come back high, but did not.
  • will62
    replied
    Doesn't sound like good comms between the main ic and the flash. Does pin 1 stay low, or go back to a steady 3+V after several seconds?
  • rddube
    replied
    Hi Will, ok tried it on DC, here is what I get:
    Pin 6, I get .92V with a sine wave (small amplitude) steady.
    Pin 2 & 5, I get .32V straight line no waves steady.
    Pin 1, I get .32V but about every 2-3 seconds I get a spike (it's too fast to see the measurement) and it is constant, every 2-3 seconds like a heartbeat. It stays at .32V and only comes high with the spike that lasts a micro second.
  • will62
    replied
    Sorry, I told you AC on the crystal, and didn't tell you to change to DC on the flash. See if that makes a difference. I'd be surprised if the data signal was more than ~300mV. Data in (p5) activity should be brief. Short instruction to read code and send on data out (p2). The data out should run longer. The clock will run during the entire process. Pin 1 will go high again when the chip finishes loading the code. I don't think that you should be able to see the square waves with your scope. They're as high as 85MHz. Maybe you are picking up extended high or low signals that indicate something in the process.
    With your scope, you can't see much. We are just trying to confirm that the flash is accessed (p1 low). There are very high speed signals on pins 6, 5, and 2. Then pin 1 goes high again when process is finished.
  • rddube
    replied
    Ok Will..on the crystal I get 2.01V, at pin 6 I get .92V and pin 2 and 5 very low .2 .3V. However on 2 occasions, while probing pin 6 and 2, I saw square waves and they were on steady, then I couldn't replicate it. On pin 6 the square waves were much larger than those on pin 2, but they were nice and regular. Never saw any square waves on pin 5.
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • Noodneek
    Replacing all the caps on the BenQ SW2700pt's power board didn't help...
    by Noodneek
    My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
    I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
    08-30-2024, 12:52 PM
    09-06-2024, 05:59 AM
