Hp envy VBUS50 LA-9511P REV 1.0 DUMP NEED
  • cacla
    • Apr 2015
    • 444
    hi there i need dump for this board LA-9511P REV 1.0
    I need main and EC bios
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
    by JDC
    ONN 100012588
    Issue: No Power, Then Rebooting After Main Board Change
    Short answer: replace main board and power board
    Technical answer: replace main board and Q306 & Q307 on power board.
    Long answer:
    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
    07-15-2022, 07:39 AM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
